but everything I ever buy is overkill, lol.
well have i got a new car for you.....
I can finally work on models with out the PC freezing every 2 mins when you click on a pixel
previously the 3d work was around 50K poly now working on 200-300K poly models
which look sooo much better when doing 19,000 X 10,000 renders :cheers:
Edited by Whiplash
hi all.just wondering what you all use as a media player on ur PC?
i use VLC, love the layout and most things about it. the issue i have is it freezes over the lan, and also on my desktop... i have used the googleizer and tried the things suggested there, increasing the buffer helped a lot, but i still get the freezes :)
in the past i was a big fan of media player classic, but i find the playlist a bit clunky so i have been persisting with VLC.
does anyone out there use anything else that is worth a shot?
...::edit::...
my os is win 7 ultimate
Downloading VB 2010 Express at the moment (http://www.microsoft.com/express/Downloads...10-Visual-Basic). I remember using this years ago, I'm willing to have another play around with it to see what it can do.
Carl give ZPlayer a try ..... I use if for watching DivX movie/tv dls and it works a treat. Seems to handle different file types and codes better when doing fullscreen than all other apps I have tried. I also use the CCCP ffdshow/codec pack - has always been great.
guys I've got an old Benq laptop that does pretty much everything that I need for work.
Except for a little more speed, I'd be happy to stick with it for another year or 2.
Thing is, it has an IDE HDD (not a SATA) so going to an SSD to improve performance is pretty much out of the equation.
Anyone here ever configured an SSD into an IDE connection?
Depends on if you have 1.8 or 2.5" PATA drive;
http://www.solidstatecentral.com.au/store/...8b79bfa4f8f3fc6
I've bought runcore SSD"s off these blokes before and used them as upgraded drives in EEE's. Work very well.
-D
The transfer rate of IDE wont give you any decent performance with a SSD over the normal drive. But if you are keen on the SSD idea still, you could use an IDE to Compact Flash converter.
this is what I'm worried about........if the controller is the limiting factor then it's probably pointless spending $300 - $400 to gain little if any speed at all......better off puting it towards another laptop maybe.
This is what's in it now:
WD1600BEVE Scorpion Blue
160Gb 8 Mb cache 5400rpm 2.5" PATA
the transfer rate will be a sustained rate rather than a variable rate and there will be no seek or write latency
you'll notice the difference. put it this way, ATA supports up to 133mhz bandwidth, SATA is 150... SATAII 300... etc
diff between sata1 and ide is not much at all - esp since your drive is a 5400rpm its slow as dogs balls...
the other benefit is the wd probably runs 5watts when seeking and reading, the ssd will be about 0.1watt peak. You'll save a fair bit of battery with an SSD..
-D
you reckon the extra minimal performance difference is worth the dosh though?
Wish I had some figures or comparisons between my drive and an SSD on an EIDE controller
for the price? frankly no.
buy a new laptop with an ssd already in it, if you want the bang for buck
however ssds will speed up ur system, including outdated ide buses
-D
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
