Yeah they use geforce quadro's for cad at my work. Pretty good cards for rendering 3d models in complex detail. Not good for gaming ;P
-D
Not to mention pricey, last time I looked...about 6 months ago, they were around the $1k mark or higher.
-D
What CAD systems are they using?
It will be used for predominantly CAM applications, Edgecam to be specific. With a bit of CATIA and SolidWorks thrown in for good measure. Tool-path verification will be what i need the graphics power for. Unless it is coded to support some GPU computing, which I doubt.
Is it worth going for a workstation card even if the program isn't specifically supported with drivers? Or would I be better off spending the same coin on a gaming card which will have more brute power, however not as fine tuned?
anyone got a decent computer for sale cheap ??
i have a barebones chassis (case + motherboard, u would have to get the rest) in my cupboard that i'd happily part with. had big plans but went in another direction.
lemme kno if u want more details /pics etc
Heaps. Wonderware, Autocad, Altium Designer, etc...
Depends on the software - I'd check with the manufacturer. No point spending $1k on a card that the software cant use.
-D
500 just the tower i got monitior wanted for some vidoe editing nothin spectacular and just crusing the net
glad to see you bought only what you needed
many people get sucked in
count yourself as not one of them ;)
-D
I asked Adam a few weeks ago to change my Internet Plan to their new plans - AdamBasicChoice 100GB, which is up to 20Mbps.
So my account rolled over the other day, and I hadn't received my extra speed - was a little pissed, so I sent them an email, and they replied saying it was going to take 3-5 days, as the wholesaler still had to apply my upgrade.
Well, I got home today from Balgowan, checked my speed, and I am rather happy with it :)
Had torrents going at the time, but I am not going to complain.
If your with Adam make sure you up your connection profile. I've got a SNR of 6 and run stable on their second to fastest profile. I sure noticed the difference over standard.
I have no idea how to do that, but with my modem - Billion 7300GRA with Autodetect settings, I get this
You've also got to watch the error correction, speed and snr often look good on higher profiles but a good chunk of speed can be lost to correction on not so good lines.
If you're on an Adam dslam, jump on the members page and go to 'View Performance Profile'
Nope, don't have that option. Most likely as I am on ADSL not on ADSL2+, even though my modem is using the ADSL2+ protocol to sync...meh, I am happy with the results - downloaded 1.4gb in 10-20min :)
Sure it's not ADSL2+ over a telstra dslam?
"ADSL" will get you 8mbit/1 and "ADSL over POTS G.992.1" 12mbit/1.3 under perfect line conditions.
Adam can still tweak the line profile, but you've got to call up to get it done.
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
    • shit boxes, kids, and daily drivers are all welcome
    • Cam seals go hard. It's a very old car.
