Yeah they use geforce quadro's for cad at my work. Pretty good cards for rendering 3d models in complex detail. Not good for gaming ;P
-D
Not to mention pricey, last time I looked...about 6 months ago, they were around the $1k mark or higher.
-D
What CAD systems are they using?
It will be used for predominantly CAM applications, Edgecam to be specific. With a bit of CATIA and SolidWorks thrown in for good measure. Tool-path verification will be what i need the graphics power for. Unless it is coded to support some GPU computing, which I doubt.
Is it worth going for a workstation card even if the program isn't specifically supported with drivers? Or would I be better off spending the same coin on a gaming card which will have more brute power, however not as fine tuned?
anyone got a decent computer for sale cheap ??
i have a barebones chassis (case + motherboard, u would have to get the rest) in my cupboard that i'd happily part with. had big plans but went in another direction.
lemme kno if u want more details /pics etc
Heaps. Wonderware, Autocad, Altium Designer, etc...
Depends on the software - I'd check with the manufacturer. No point spending $1k on a card that the software cant use.
-D
500 just the tower i got monitior wanted for some vidoe editing nothin spectacular and just crusing the net
glad to see you bought only what you needed
many people get sucked in
count yourself as not one of them ;)
-D
I asked Adam a few weeks ago to change my Internet Plan to their new plans - AdamBasicChoice 100GB, which is up to 20Mbps.
So my account rolled over the other day, and I hadn't received my extra speed - was a little pissed, so I sent them an email, and they replied saying it was going to take 3-5 days, as the wholesaler still had to apply my upgrade.
Well, I got home today from Balgowan, checked my speed, and I am rather happy with it :)
Had torrents going at the time, but I am not going to complain.
If your with Adam make sure you up your connection profile. I've got a SNR of 6 and run stable on their second to fastest profile. I sure noticed the difference over standard.
I have no idea how to do that, but with my modem - Billion 7300GRA with Autodetect settings, I get this
You've also got to watch the error correction, speed and snr often look good on higher profiles but a good chunk of speed can be lost to correction on not so good lines.
If you're on an Adam dslam, jump on the members page and go to 'View Performance Profile'
Nope, don't have that option. Most likely as I am on ADSL not on ADSL2+, even though my modem is using the ADSL2+ protocol to sync...meh, I am happy with the results - downloaded 1.4gb in 10-20min :)
Sure it's not ADSL2+ over a telstra dslam?
"ADSL" will get you 8mbit/1 and "ADSL over POTS G.992.1" 12mbit/1.3 under perfect line conditions.
Adam can still tweak the line profile, but you've got to call up to get it done.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
