Yeah I run my Quad core AMD 965 @ 3.825Ghz all day every day (it was 3.4Ghz stock) - but I have taken it to 4.3Ghz (it is water cooled) ... temps went a bit high when playing Crysis 2 at full res though, so turned it down. TBH the performance benefit of 4.3Ghz over 3.825Ghz is negligible anyhow. And my dual 64Gb SSDs are not a choking point either.
I've sent my OCZ revodrive back. Kept corrupting the partition every time it would shut down. Something seriously wrong there. Hopefully they give me an upgrade once its verified faulty
-D
Wow that sucks Ben. I seriously thought about buying one for a decent clients machine I was building around that time, but ended up erring on the side of caution. The lack of TRIM support had me worried.
Hope yours gets replaced with the upgraded version with TRIM and idle garbage collection support.
I had a 200Gb A-Ram SSD with Sandforce Controller that shit itself after 10 mths in my office machine....................they've got a long way to go with these new drives cause I've never had a SATA or even an Eide drive die on me since Win95 1st Edition
This one doesn't have anything to do with TRIM or the garbage collection
Rather, its still writing data when the motherboard powers down - either the drive or Win7's handling of the shutdown procedure is bunk.
The x2 drives are a significant improvement - theyre also significantly more expensive. I doubt I'll be given one of those
-D
You don't want to stripe, if one goes you'll lose both, doubling your chance of failure. Mirror with 2 disks or RAID5 with three disks is good for backups, both options have 1 disk of redundancy with RAID5 giving a performance increase. Raid0 is only for going fast and for anything you don't want to keep.
If your data is really important, get a docking station for a HDD and back up onto a 2TB drive and then unplug it and put it in your safe. Raid is good if a disk dies but if you get a virus or accidentally delete something you're still screwed. Having the drive unplugged also protects you from stuff like power surges, theft and system malfunction.
striping is fine for operating system data, esp when you have the MBTF of a modern SSD
Eg Revodrives are internally raid 0 to get their 540MB per second reads
-D
All good points, personally what I would do is if you don't have a huge amount of important data to back up is do this.
Stripe 2 or 3 High performance disks together, and then have another 2Tb backup drive. Now you could mirror to the 2TB, but most the time half your data you don't care about, so do what I do and every night backup all your documents and settings folder, desktop, my docs and any other important data etc. That way if you lose a disk you just format and copy your data back. If you can afford it do a mirror as well but often it is unnecessary. I don't run a stripe, but I do the same thing in principle with my drives.
I have about 5 disks, I backup everything important from one disk to another disk each night, assuming I only get one disk failing at any time, I don't lose any data. I also backup to dropbox, and then via dropbox to my work PC.
Edited by Rolls
  • 1 month later...
hey guys, good to see this thread is somewhat still active.
Kralster get back from E3 trip? How was it, I watched it live and thinking about going there next year.
And have any of you guys heard about the new tech scheduled for later this year from AMD and ATI? I am building a PC around october and still unsure whether to grab a 590 or 2x580s and have not heard anything ATI has to offer.
That guy is still around? :blink:
    • Time will tell, they're doing all the admin stuff at the moment. I've submitted all the required details, photos, etc.   I was under the impression that DC coupling is the best approach, i.e.: Solar Array -> Battery Invertor -> Battery  Where as AC Coupling is simpler, however less efficient, i.e.: Solar Array -> Solar Invertor -> Battery Invertor -> Battery
    • The price is really great for that kind of capacity. I thought similar setups cost way more. How's your efficiency been with the DC-coupling? I've heard sometimes there can be a bit of a performance loss.
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
