Internode & iinet are soon to be basically the same thing ;)
http://www.abc.net.au/news/2011-12-23/iinet-internode-internet-broadband/3745066
Yeah. Hackett reckons its "all gonna be status quo" but I've worked for ISPs that have been absorbed by Ozemail/Worldnet/MCI Worldcomm/Iinet.
Frankly, their words are worthless. They say anything to float company shares (as any self respecting capitalist would do - cant hate them, they're looking our for their shareholders. kudos)
BUT
they do it at the expense of truth and so nobody can ever trust em
Hackett reckons that Node will continue as usual. BS. They'll (as primary shareholder) go ahead and absorb all infrastructure into their own brand, sack all PR people (HR, Admin, Call centre, level 1 techs) and the centralize to the pre-existing iinet hub.
The days of the little ISP are over. RIP. Now we have to deal with asshole conglomerates...
-D
anyone know a decent ISP for gaming? the fluctuation that i get with bigpond atm is really shitting me off! any help would be appreciated thanks.gif
I play online quite a bit mostly BF3 of late. We've got Adam naked adsl2+ and I'm more than happy with it. Telstra have been pedaling their cable service around our area lately but I'm happy with what I've got.
I'm pretty impressed that when Adam change say their $60 plan to include more downloads, they apply it across the board, so everyone paying $60 gets the same. We started at 12gb and are now up to 100gb. Also if you're under contract to get your install or modem for free and want to stop your service or go to another ISP, all you have to do is pay the remainder of the subsidized items, not the monthly plan amount X months left on the contract. It just seems like a much fairer system that simply makes sense.
yea i just done a snoop around.... found out that we are paying 80 buks or something around that mark for just plain old ADSL, when they have the ADSL2+ for the same amount!!! so jumped on that and fixed it up...hopefully we see some sort of difference in that thumbsup.gif
  • 3 weeks later...
So my external HD USB connector has snapped off inside the HD, is there anyway of retrieving the data off the HD?
Yep theres a mob in melb with a clean room that can remove the platters and chuck it into a byte reader and get the data off but its pricey
-D
  • 2 months later...
    • I didn't think about how a circle works before, dumb.  Before, I had .9mm restrictor bolts but I can't use these cause they were shorter aluminium bolts that just tear off their threads when tightening since the OEM lines are thicker than the shitty braided one that was installed previously. Now I use longer 1mm stainless steel restrictor bolts. I think the difference will not affect the health of the turbos, but I guess I'll have to drill out the main feed bolt as I agree multiple restrictions sound dodgy. The one that was installed with the braided line was just too short, but completely without a restrictive hole.
    • Tomei or Nitto, don't use the OEM one or Cosmetic ☺️
    • After cleaning up a rusty cooling system in a 33 gtst that's been sitting for years it seems to have cleaned out the head gasket too haha. It seems the Tomei metal gasket works without machining surfaces? Or put oem? Also should put an oil restrictor while the head is off? Thanks
    • Thanks, I definitely saw the more expensive options from Crank and driveshaft shop. Thank you for the D-max option.  Still hopeful someone has an OEM out of the box option I found that the 300zx NA Left drive shaft is a good match for the Right on the R33. https://www.gsplatinamerica.com/product/ncv53040 Just need to find Left CV for the R33, I cannot find any <=22" axles.
