Petrol Usage
Z32 AFMs are 80mm tubes. RB26 AFMs are smaller. Just measure. Nismo RB26 AFMs have a different part number to original 26 ones. Probably also have a Nismo badge - but I don't know because I've never been near one. It's unlikely that they've been changed anyway.
Hey looking for pointers or experiences with indicator wiring/ common faults for the blinkers on the r31, I have a 87 silhouette and am having dramas with the blinkers staying on (not flashing) to indicate right,while trying to indicate this way the relay makes a constant noise, The front passenger side fender blinker is missing the harness connector to the bulb so is not connected would this effect the opposite side? Both rears work as they should, and blinker that stays on functions normally when on hazards instead of indicating, have replaced all bulbs,fuses and relay Cheers
I’ll check the AFM’s and confirm. I’ve seen on another forum post years ago it’s identified with an orange sticker and larger diameter. Unsure if I can check the diameter without removing the air filter. Is there a way to identify if the AFM is stock? I’ve done a quick search and it looks like it might be a green sticker instead? Will try check that turbo core tag. Looks like a very tight fit in there. Do you know what number would show if it was a stock T25 turbo?
The car and the 33GT-R wheels look great. I can't remember if spacers were needed for these but the offset looks perfect for the GTS25t.
And the lack of ubiquitous availability. If it was less likely that I'd run out of fuel while trying to cross the crime zone, I'd probably be all over it.
