  • Replies 43
We also need a design maybe people could come up with some and we could have a vote or something to decide.
I think something simple kinda like the ones found in the S15. mostly plastic with a metal insert with "Silvia" written on it.
Looks horn.
If anyone has the exact font that the SKYLINE word is written in, I'd appreciate it if someone could send that to my email
EMAIL - satanic @ optusnet.com.au
Kickplate coming off my car for measurements tonight then the design will be sent off for fabrication. Etching process will be the last thing done, I just want to see what the overall effect will be like first.
Just so you know, we can put any design onto these plates... the majority will be SKYLINE but we can cater for anything custom providing you give us the design. Plates will be done in Titanium with a Silver/Gold plate (again by preference).
Titanium was decided upon as it is very workable and very very durable which is exactly what you want for something that will see a lot of rough work (shoes, dirt, knocks).
Approximate Costing:
SKYLINE panels will be mass made and will be the base price.
CUSTOM panels will be made to order and will obviously cost more.
Silver Plating will be the base model.
Gold Plating will be a premium option.
I had a sample sent over that was made in Titanium with a Gold Plating + etching; this was a once-off prototype and cost $150AUD. Obviously the final product won't cost anything like that - this was just a sample and a prototype :dry:
OK little update yet again;
The CAD Drawing for the R34GTT kickplate has just been done up... for the R34 we've decided to do 3 seperate pieces;
LEFT >>> CENTRE (SKYLINE) <<< RIGHT
We've decided that a full replacement will NOT be the best option, as the costs to make the mould will be very high. If a direct replacement must be used, Injection Moulded Plastic must be used (costly).
Normal Fibreglass would not be good for this item as every time you take it off for service/installs you would run the risk of snapping the panel in half.
As such we are making the metal kickplate inserts that will be integrated into the existing panel. The adhesion process is still be sorted out (deciding between an adhesive or a bolt/rivet).
Update from the supplier - three colours will be available;
1) Titanium Finish (Silver - Chrome)
2) Titanium Gold Finish (Gold Plated)
3) Titanium Black Finish (Black - Glossy)
The third option I did not think would be chosen but I have had some members ask whether it could be done as they have sprayed the kickplate some other colour (e.g. white)
I am hoping to have the first prototype of my kickplates done within 2 weeks. Please be patient for this process to take place.
SOMEONE GET ME THAT SKYLINE FONT!!! ALL GOOGLE IMAGES SUCK!
Thanks mate... having the font will be much better than blowing up a logo in picture format. We'll be able to load each character into the etching machine instead of a flat image - means cleaner cut letters.
Also, if any of you are lawyers or professionals in intellectual property law - could you please advise on the legalities behind using the SKYLINE logo? I know for a fact that using the GTR logo is prohibited inside Japan.
I had a read in the law books at home and there is something along the lines of a disclaimer I could use? Something like this product is NOT genuine Nissan and is in no way endorsed or related?!? Someone please advise...
Thanks
S
heheh damm, should have bought my friends one..
it came with his car, and looked really nice (silver-chrome one with Skyline engraved)
Pretty sure, you can purchase these from japan local shops.. Or maybe it was a factory option??
OK designs sent off - didn't end up using that SKYLINE logo that n15m0 found us (sorry bro), so what did we do?
Stay up till 3am measuring every damn mm on the real kickplate and making our own SKYLINE logo on AutoCAD. Took forever, but the end result is spot on.
Nothing like a set of digital calipers and pen + paper!
It's looking good boys, now the wait for the prototype to be returned - update soon!
Thanks guys! Appreciating the support and feedback...
I like EMERGENCY EXIT :laugh:
Personally I will have a set of SATANICs made up~
I did ponder with one idea though, having a laser etched "carbon fibre" look will also be doable. As a laser is being used to etch the metal, all they have to do is "weave" multiple layers onto the one sheet using different laser intensities - EASY!
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
