Hello, I am selling this car on ebay and thought i might give you guys a link.
eBay Link
Here are some specs:
Body Styling:
Pumped Guards
Resprayed Metalic Purple
Limited Series II Bodykit (very rare)
19" Mags
"Shaved" lines and boot lock
M3 Side mirrrors (made to fit)
Drive Line:
Manual, auto electronic drag gearbox ($8000 gearbox)
4000rpm custom build stall converter
Tightened limo diff
Large race transmission cooler
2" Wheel extensions
JH Magic adjustable coil overs
Large race sticky break pads
Fuel/Ignition System:
700hp oversized injectors
600hp bosch fuel pump
Malpassi regulator
Modified crank angle sensor
EMS Computer system
Performance:
GTR 1000hp intercooler
Garet T04 Turbo
Spagetti built manifold, with equal runners heat wrapped
Huge large capacity polished plenem
Stainless polished pipework
XT huge throttle body
3.5" Stainless pipework, 5" Canon
Blitz BOV situated at front for loudest noise (filter to quiten included)
Blitz turbo timer (talks to you in Japanese)
Has just over 37000kms on the clock, was imported with around 32000kms. so has only done around 5000kms since in aus.
Im looking for around $17500
Dyno graph:
Edited by necrodon
https://www.sau.com.au/forums/topic/109424-1997-r33-gts-t-skyline/
is this for real ? stock internals ? waaaayyyy cheap... its just to good to be true... no way.. paint job alone cost arm and a leg yet the amount of mods done for just 17,500?
ok... whats the catch ?
No catch, the interier is all stock.
The car is in beautiful condition, very fast car...
the bids on ebay are already around the $6000 mark, so im hoping to get what i want for it
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
