Yeah you always get people tagging along or adding them selves on half way thru a cruise its cool tho!!. If I saw 50 skylines go past or in a carpark I would be following them....
Do the cops know about this cruise??
Just Curious
:P
i will let the POLICE know just before we go :D
  • Replies 283
Posted Images
There is no difference, except there will be more cops, guarunteed radars, more attention... it's just more fun if you dont have to constantly watch your speed and watch your back for cops... I never speed excessively, but double demerits weekends are when they are out there specifically to hit you up for 6 points for doing 16km/h over the speed limit. Fawk that!
90KM/h is so damn slow...
I just went to the central coast from lidcombe... 15 cops on the way!!!
Be careful peeps!
OMG!!! I just noticed this, it will be so usedful!!! :P
so is this cruise open to stageas?
i still come from the nissan family...
anyhow were from newy so we'll meet you guys when you regroup off the freeway..
any idea's on what tym or near abouts to what tym you will be nearing there?
the other half is up for it too so he'll have his car as well.
so add us to the list of definates mum's taxi and brizzi
Hey can you tell me what time do you think you will be getting to the twin servo's we want to meet up with you guys there cause it to far to go to homebush from East Lindfield or what time you think you will be hitting the F3?????
Cheers
Andrew
anyone going to the cruise from sydney's west? i might be going, would be good to meet up with some westies first, then take off.
meet up at Hungry Jacks, Cumberland Hiway at 9:00am for a sharp 9:30am departure to Homebush P6!!!
i think a few of us may be meeting you (e.g. me - if i can make it, rb30gtr etc) lot at the F3 start - do you guys have an ETA for when you'll be at the F3 start ???
guys just to let you all know, we will be departing P6 at 10:30 sharp, so please do not be late we will not wait for you.
if things goes to plan, we will be on the entrace of the F3 by 11:15am, so if you guys just wants to stop one one of the sides st till u see us coming, if not we will have radios on, will confirm channel, if not you guys can call me on 0404316910, and just check wif me how far we are.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
