  • Replies 283
Posted Images
Here's two of my favourites..
Had alot of fun guys, hope to do it again. With even more of you, and next time I won't walk off to get a burger...before we line the cars up to take shots... ( didn't know lol : )
My mistake...
im exhausted from the cruise......but IM HAPPY!!!!!!! The cruise up newcastle was kinda lonely, thank Jon (primordial) for keeping us entertained on the cb.
Just wanna say hi to everyone I met there, chances are I've forgotten you name already, but not the face. And a big thanks to Jeff for organising this cruise.
Alien, stop slacking around and get them 400 pics up :whistling:
saw you drove pass me around horsby area.....I was stuck in traffic
also saw a whiteR33, silver R33 and a R32 on the side of the road around berowra, didn't know who they were, too dark to see, but gave a beep and a wave. :whistling:
Edited by lingeringsoul
hi all nice turn out 2day
i got quite a shock how many cars actually made the trip
i've got some pics to post up just need to upload them first
it was good to meet some new people
maybe next time us newcastle people can organise a cruise down to meet all you sydney guys..
also saw a whiteR33, silver R33 and a R32 on the side of the road around berowra, didn't know who they were, too dark to see, but gave a beep and a wave. :bunny:
ohh!!!! so you're lingersoul! LOL!!!! :) it was us you saw regrouping and having a chat after the old pac :(
oi! you bastard, thought i woundn't see this didn't ya!
a no show by you too!
He showed up :)
All the rest of you Sydney kids had left before they got there, though...
A couple of us stuck around for a bit longer :(
He showed up :)
oh! lol
We ccame back to that car park at about 4.30 and there was just a few people left!
must have missed him!
oh! lol
Whoa :)
They can't have stayed for long then, 'cos we left at 4pm.
They were all there when we left :(
Where did you guys go?
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
