Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Guest 87vlt
Originally posted by BelGarion
ill take the catback off, it will still have 7psi below 5000rpm and 9psi above 5000rpm
thats the way r33s are from factory.....
hell if ur that desperate to prove it wrong, ill take my exhaust off and drive it round the block
1. ull see no change in the boost
2. ull pass out from the gasses
3. cops will be called cause of noise
but it will still be 7psi below 5krpm and 9 above it
4. you would loose power by removing your exhaust. I am in that situation right now cause my exhuast is getting re-fitted on Monday. It sounds like crap and goes like crap.
5. I got a exhaust and my boost went from 6 psi to 7.8 psi. Almost a 2 psi gain.
6. removing your exhaust is not going to increase your boost. You've already had a boost gain. try fitting the original restrictive factory exhaust.
7.
thats the first time I've heard that. I'm almost certain that factory boost is between 6 and 7 psi - well according to HPI and Zoom anyway, unless of course they have no idea what their talking about (which could happen) and in which case you would be right.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
