Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
i didnt run last night because im selling my car... its killing me!!! if i come back from overseas and i havent sold the car... i will be boosting so it makes 450rwhp, buy some slicks then take it down the 1/4.... otherwise i wont be seeing the 1/4 for a long time... i just had to come out and watch... cant stay at home when u know the runs are on!!
Guest 87vlt
Originally posted by Skyrine-Dave
should i build an RB25/30 combo, find a cheap RB25det, or bolt a HKS2530 to my current RB20det?
rb25 ... too much custom stuff in a rb25rb30 engine. the rb20 .... meh ... they may be faster than me but don't really impress me by any means.
Guest 87vlt
boxhead .... did you break out into insane amounts of wheelspin to get that time? if you did you da man ...... looks damn kewl from a spectators point of view. Seeing one car in one lane getting a nice smooth launch and another sitting on the spot spinning its arse off .... :P
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
