Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
haha Dragon - i like her attitude ;) !!
I have something against Honda Civics - man those cars just have a way of rubbing me up the wrong way - they think with the clear taillights, neons and tonnes of stickers they can beat u - yet they get chopped everytime haha
They whinge and whinge about not having somewhere to meet and catch up on thursday nights mainly and that they keep getting hassled where every they go, and Andrew and I have decided to get off our arses and do something about it and organise a carpark to have our meetings in and this weekend is a tiral run of it, and no ones attending. Cept like 10 skyline people from here.
man in WA everyone is real eager for a cruise!! we've been having secret cruises so we only get a few cars and not like our normal 40 odd which attracts tonnes of police attention!! Its so annoying when u go outta ur way to do something then its not appreciated!!
off topic but my cat has really missed me while ive been away - shes curled up on my lap now haha my lil hot water bottle ;)
yeah i love my cat too - i had to leave her outside for four days while i was away tho cos no one was home to let her out when she needed the loo. it broke my heart cos she normally sleeps on my bed all day and she had to sleep in the cold - but she survived ;) shes even gotten fatter!!
my cat used to be real fiesty n independant (shes a tortiseshell apparently thats their personality) now all she does is sleep all day and if shes on my lap and i go to move she digs her claws in - the more i move the deeper the claws go!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
