Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Sad pathetic little me
That was the girl I used to be
You left me on my knees
I'd trade you places anyday
I never thought you could be that wayyy
You look like me on sunday
Oh you came up with the breeeeeeeeeeeeeeeeeeezeeee
On SUNDAY Morning
Sure I haven't changed since yesterday
Without any warning
I thought i knew you
I thought I knew you
I thought I knew you Well
SOO WELL
Your trying my shoes on for a change
They look soo good
But fit so strange
There fashion So I can't complain
On SUNDAY Morning
Without any warning
SOO WELL
Oh lauren. I'm sorry :D
Hahaha.. **** my cat's funny. She runs in and jumps up and smooches me so I knwo she wants her dinner. If I don't get up she ususally gives me like 5 minutes then comes back.
Tonight I think she's really hungry. She just smooched, ran out to the kitchen, ran back and and smooched me again :|
I think she's hungry.
BBS
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
