Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Here is a transcript from the current Speed Magazine (issue 0:07). I found it absolutely hilarious. They are all real names given to actual production models in Japan.
DAIHATSU
Rugged Field Sports Resin Top (1997 model): What, did they give these away on Survivor Africa or something?
D-Bag: Could stand for Douche-Bag or Dime-Bag, or something else far less appealing than a tea bag.
Town Cube (an esky on wheels): A people mover and Rubik’s puzzle all wrapped up in one.
HONDA
Acty Crawler (a six wheel truck with tank-like treads: It'll clean your swimming pool in three hours all by itself.
Joy-Machine: Sex on wheels. Available in five-speed manual, four-speed auto and three-speed vibrate.
ISUZU
Big horn (1993 4WD): Either a tribute to jazz great Miles Davis or porn legend John Holmes. We're not sure.
Mysterious Utility Wizard (Current short-wheelbase Rodeo 4WD): Gandalf's transport in the upcoming film son of rajab of the Circle Work.
Giga 20 Light Dump: Standard specs include vanity mirrors, four cup holders and a toilet paper dispenser.
MITUBISHI
Pajero: What's weird about that? It translates directly to "mastabator" in Spanish.
Canter Guts (current Canter truck): The toughest ride for the blue singlet set. Imagine the tradie TV ads for this one.
Aero Queen (1990s tour coach): The bus of choise for those priscilla desert road trips - or Bronski Beat tours.
Delica Space Gear Cruising Active (1990s 4WD van): The hippie Kombi of the '90s. Availale in tie-dye. Frequently seen in the car park at Gratefull Dead concerts.
MUM 500 Shall We Join Us? (1993 micro car - and yes, the question is part of the name): Sounds like a dinning table on wheels with an optional dishwasher.
Mini Active Urban Sandal: Also comes in Ugh boot and Thong spec.
Liberto RVR Super Wild Gear: Redefines the term "dealer special". Usually seen parked next to tie-dyed Delica Space Gear Cruising Actives at Gratefull Dead concerts.
MAZDA
Carol (1962 KEI micro car): "On the first day of Cristmas my Mazda gave to me..."
Autozam Carol (1989 model based on the Suzuki Alto): "Autozam the red-nosed reindeer..."
Luce (1974 Japan-only RX-4): Pronounced "loose". Costs $100 for half and hour, or $150 for the full hour.
Luce Regard (1978 Crown-style model): "What's that you're driving tonight buddy?" "My sisters Luce." "So, the rumours are true!"
Bongo Brawny (current commercial van): It's named after a croc wrestler from the Northern Teritory, Bob Marley's old drummer or a new character on Bob the Builder - we're not exactly sure.
LaPuta (current KEI-class micro car): The shit. And you can take that whichever way you like.
NISSAN
Cedric 300LV VIP (current luxury sedan): Comes with a sherry dispenser for those long trips to the opera.
Gloria GranTurismo 300 Ultima-Z (current luxury sedan): The choice of hairdressers throughout Japan.
Leopard J Ferie: The drummer from Leopard Ferie's only got one arm!
Prairie Joy (curent people mover): Heart-warmingly bland van adored by Yanks named Billy Jo Jim Bob, Sue Ellen, etc.
Big Thumb Harmonized Truck (current semitrailer): The new album from Silverchair.
SUBARU
Justy (current Swift GTi look-alike): Rusty, Busty and Dusty lost out after poor feedback during market research.
Gravel Express (Japanese limited-edition WRX wagon): The hip new rally ****tail made from sake, vodka and soil.
SUZUKI
Alto Afternoon Tea (KEI-class micro car): Replaces the short-lived Alto Smoko.
Van Van (not a van at all, but a 1970 125cc motorbike): What what? Go figure figure.
Every Joy Pop Turbo: Named after an unreleased Spandau Ballet album.
TOYOTA
Synus: Sniff! Well, it sure beats Syphilis as a name.
Estima Lucida G Luxury Joyful Canopy: Shorter than Mitsubishi Ralliart Lancer Evolution VI Tommi Makinen Limited Edition, yet much dumber.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
