Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Lucky there was dew all over the car and it didn't set. Lucky the spastics had no aim. One egg hit my mag, the other hit the drivers side mirror and the front quarter panel. The only reason I noticed it was the car looked extra shiney to be just dew and there were streak marks in the dew. Lucky I care for my car enough to look at things like that.
THEN I went to start the car and the battery was flat. It was soo flat it wouldn't clutch down our hill. Ended up having to jump start it, drive it to a carwash place, high pressure hose the egg off and then come home. By that time it was 2am and I was ****ed.
Last week I had someone put stickers on it.
Pretty damn sick of it. Time to invest in a shed I think
Guest Boxhead
erin - im sorry to hear that, if you ever happen to find the little shits, instead of pouring eggs on there car, put some battery acid.. and then invest in a nice hand held weapon, maybe a colt .45 and just sit and wait... next time they come back, aim for the spine, dont try and kill, just paralise...
Guest Boxhead
kryz - there is this bloody huge pot hoel out teh front of my house.. just out from my driveway, every time we come in and out of it in my car we gotta look out for it...
im tempted to fix it myself coz i know council are assholes...
its like say 50cm round and same down
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
