Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Lucky there was dew all over the car and it didn't set. Lucky the spastics had no aim. One egg hit my mag, the other hit the drivers side mirror and the front quarter panel. The only reason I noticed it was the car looked extra shiney to be just dew and there were streak marks in the dew. Lucky I care for my car enough to look at things like that.
THEN I went to start the car and the battery was flat. It was soo flat it wouldn't clutch down our hill. Ended up having to jump start it, drive it to a carwash place, high pressure hose the egg off and then come home. By that time it was 2am and I was ****ed.
Last week I had someone put stickers on it.
Pretty damn sick of it. Time to invest in a shed I think
Guest Boxhead
erin - im sorry to hear that, if you ever happen to find the little shits, instead of pouring eggs on there car, put some battery acid.. and then invest in a nice hand held weapon, maybe a colt .45 and just sit and wait... next time they come back, aim for the spine, dont try and kill, just paralise...
Guest Boxhead
kryz - there is this bloody huge pot hoel out teh front of my house.. just out from my driveway, every time we come in and out of it in my car we gotta look out for it...
im tempted to fix it myself coz i know council are assholes...
its like say 50cm round and same down
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
