Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
I got my car serviced on Friday. It's not running very well. I dont know whats happened. It's cutting out at idle and the revs aren't picking up by themselves when I first start the car. I've got to stab the accelorator to start it.
ANd I need to get my timing belt changed :) Doh!
Guest Boxhead
yeh thats basicaly whats happening to myn, but its got new spark plugs.. well newish, and it started great with the battery was new, but the new one is dying coz its not charging back up when i drive( which is alternators fault again!!! grrr...
ohwell.. erin - seriously check your battery indicator thing to tell you how charged it is.
Well mine only has the problem that you have to give it a bit of gas to start when cold...then the revs pick right up. Other than that all is sweet.
I've seen quite a few photos now that Justdave has taken of your car....i just assumed that he liked it. :D
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
