Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Wayne hate to break it to u .... but its not an area the D.O.T systems have access to - they can see how many points u have left but in that department thats as far as the access goes. As for your cop lady friend - if she wants to keep her job then ur screwed besides depends on the department she's in and what exactly she has access to as well ..... not all cops have the ability to change records - and the records that are changed are well documented what was changed and by whom.
Sorry
u shoudl its heaps fun. i took this girl out ness.
and she coudlnt take it LOL she thoguth when i said i drifting i was jsut spinning the wheels a little and that im a idiot driver. took her sideways in this crucuit with a few other mates followinf drifing in tandems orta thing fairly close, then i was slideing the other way ect looks nice anyhow was perfect. she was screeming and putting her hands over her eyes. then wanted to get out of my car LOL.
some girls like it tho like liz
i got new tyres .... my last set are at the tyre place waiting for paul to pick up whe he comes back from england - theres 80% tread left on them but they have some big mofo eggs in them!
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
