Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Guest Boxhead
sorry, yeh i sorta am, tomorow nite, not much, but tomorw arvo i have to trian under 16 qld hockey team, wont get home till like 7pm, but i still need a shower and and some dinner.. plus ill prolly be stuffed and have no money as per usual...
i live at tweed heads.
Guest Boxhead
and the same could be said for non gtst drivers, like some skyline in general drivers may not want non skyline owners to not be a member.. and i know that if we did that alot of us would be missing out of alot of valuble information...
in the end i dont care who joins the forum or what they drive, aslong as they respect most of the other people and aid in others having a good time.
Guest Boxhead
hrrmm i dont like skyline owners who bought a skyline coz 'the full sick chicks in surfers' dig them...
thats what i have found even upgrading from non turbo to turbo, i still feel i have nothing to proove, still dont do laps anywhere unless looking for a park or something...
i choose to own a skyline as i like the damn thing not because anyone else does.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
