Queensland Wasteland
i explained what i wanted, 3 rca plugs at one end and a 3.5mm jack plug at the other end, same sorta deal that you get with digital vid cameras. the guy at domayne had no idea, made me feel like i was chaising something that didnt exist either
went next door to harvey norman the guy knew exactly what i wanted
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
but there was no sales persons interested, there was 2 guys flirting with some chick who was sittin at the door, all 3 worked at amart, one of em was bein a bit of a dickhead with her and shit, so yer, i just walked out, couldnt be bothered dealing with em, they were all too interested in talkin amongst emselves rather than selling some ****ing furniture
i woulda bought it there and then if i coulda had it for 200 but meh, obviously they dont think i had the money to buy something or something, so ill take my buisness elsewhere, and probably get a better deal anyway, thats the second place ive looked and its been the cheapest so far
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
