Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
ryan will be i think
um, my car hasnt been able to touch its previous best et.
i might even get some replacement plugs cause the ones that are in it are coppers
i hate replacing my plugs tho, cause i think i overtighten em and i get scared i will **** the threads on the block :S
just found this on the net
Hi! My name is (who?)... My name is (what)... My name is
(scratches)...
Rice Burner!
Hi kids, do you like 5 inch tips?,
Wanna see me stick chrome fender flares over each one of my Konigs?
Wanna follow me and do exactly as I did?
Try NOS and get your motor f***ed up worse then my life is?
My brain's dead weight,
I'm trying to get my head straight,
but I can't figure out which sticker to put over my license plate.
And the mechanic says "Rice Burner you's a crack head”
"Nu-uh"
"Then why's your car dead, man its wasted "
Well since age 9 I've wanted an Si so I could put chrome 18's on it and make it run 16.9's.
Got pissed off and ripped all my Honda emblems off,
And replaced them with "R" badges so people know I'm not soft.
I smoke a big bowl of chron, lay in my lawn
For longer then it took me to put my altezzas on.
"Come here bastard" "Dude, wait a minute that's a viper, dawg!!"
I don't give a f***; I'll just fly by and put my hazards on!
(scratches)...
Rice Burner!
I pull up to the starting line, from a fifty roll I'm usually fine,
But dem goddamn V ten Ponies smoke me all the time.
99% of my crew I have to lie to,
I just found out a salad shooter makes more torque than I do,
My chrome 15's own, my Integra's a Type-R clone,
****, even my kanji decals are worth 10 horsepower alone.
(scratches)...
Rice Burner!
Stop the race, this car needs to be locked away.
Not even Justin Timberlake in drag is this gay.
I talk a mad line of jive, at the track I barely survive,
But an 8 foot aluminum wing looks bitchin on a front wheel drive.
(scratches)...
Rice Burner
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
