Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Ever wanted to speak like a New Zealander
[For bist efict, rid these out aloud!!!]
Milburn - capital of Victoria
Peck - to fill a suitcase
Pissed aside - chemical which kills insects
cops - for hanging out washing with
Pump - to act as agent for prostitute
Pug - large animal with a curly tail
Nin tin dough - computer game
Munner stroney - soup
Min - male of the species
Mess Kara - eye makeup
McKennock - person who fixes cars
Mere - Mayor
Leather - foam produced from soap
Lift - departed
Kiri Pecker - famous Australian businessman
Kittle crusps - potato chips
Ken's - Cairns
Jumbo - pet name for someone called Jim
Jungle Bills - Christmas carol
Inner me - enemy
Guess - vapour
Fush - marine creatures
Fitter cheney - type of pasta
Ever cardeau - avocado
Fear hear - blonde
Ear - mix of nitrogen and oxygen
Ear roebucks - exercise at the gym
Duffy cult - not easy
Amejen - visualise
Day old chuck - very young poultry
Bug hut - popular recording
Bun button - been bitten by insect
Beard - a place to sleep
Chully Bun - Esky
Sucks Peck - Half a dozen beers
Ear New Zulland - an extinct airline
Beers - large savage animals found in U.S. forests
Veerjun - mythical New Zealand maiden
One Doze - well known computer program
Brudge - structure spanning a stream
Sex - one less than sivven
Tin - one more than nine
Iggs Ecktly - Precisely
Earplane - large flying machine
Beggage Chucken - place to leave your suitcase at the earport
Sivven Sucks Sivven - large Boeing aircraft
Sivven Four Sivven - larger Boeing aircraft
Cuds - children
Pits - domestic animals
Cuttin - baby cat
Munce - usually served on toast
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
