Queensland Wasteland
Yeah. he sold it the very 1st day he advertised it on the post. it was a 93 series one though. ur's is a series 2? for that price? Well he's was STOCK TO THE ROCK besdie m specs kit. How many k's ur's done? U advertising it on tradin post or somefinK?
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
as for the 4 doorz, my brother is really keen to get one, but he's scareded he cannot resell it. Wat do u think about it? THre's like only 4 ppl with 4 doorz on this site i think - from queensland that is. and I've only seen 3 in my whole life on brisbane roads :S
yeah. well my mate had like dealers callin him up to buy his car, not just private buyers. THey offered him $14k cash, they probably would have turned it into a manual and sell it with warranty for like $22k - - as most dealers do.
Personally. u rekent buying a 4 door r33 aint too wise for my brother to do?
I believe soo too. mine is a coupe .... but my bro loves the sedan. He's seriously considering but yeah he just dreads the issue of resale. HE doesnt mind losing some $ but worst still NO ONE BUYS IT! THen he'll be in trouble when he heads back oseas
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
