Queensland Wasteland
Yeah. he sold it the very 1st day he advertised it on the post. it was a 93 series one though. ur's is a series 2? for that price? Well he's was STOCK TO THE ROCK besdie m specs kit. How many k's ur's done? U advertising it on tradin post or somefinK?
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
as for the 4 doorz, my brother is really keen to get one, but he's scareded he cannot resell it. Wat do u think about it? THre's like only 4 ppl with 4 doorz on this site i think - from queensland that is. and I've only seen 3 in my whole life on brisbane roads :S
yeah. well my mate had like dealers callin him up to buy his car, not just private buyers. THey offered him $14k cash, they probably would have turned it into a manual and sell it with warranty for like $22k - - as most dealers do.
Personally. u rekent buying a 4 door r33 aint too wise for my brother to do?
I believe soo too. mine is a coupe .... but my bro loves the sedan. He's seriously considering but yeah he just dreads the issue of resale. HE doesnt mind losing some $ but worst still NO ONE BUYS IT! THen he'll be in trouble when he heads back oseas
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
