Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
Originally posted by user
Hey does anyone know what that new single is called that the chorus goes :
detroit, new york, and LA
I am a slave of the minimum wage
The UK song :)
Should see my dads new phone its a sony ericsson got access to web - video - pictures - basically it can do everything - mini computer - too bulky tho if ya ask me.
yeah - this is a little more expensive than those phones - looks a little nicer .... its basically got all the features of a computer including window XP etc and phone in one.
I like my baby one i got now :) even if it is a hand me down
yeah but it chews thru the batteries cos its dual screen and one side is blue and the other side shines green and when ya have a message the normal light that flicks when it picks up reception goes from green to red .... so i basically have to recharge the battery every night .... luckily i have two batteries for it :)
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
