am thinking of purachsing an rb25 turbo from a series 2 R33 (apparently with the nylon compressor wheel)...
EXACTLY what would i need to make this fit onto my rb20?
eg oil/water lines? any other things?
also, what markings would this turbo have on it to ensure i am getting a series 2 turbo and not getting ripped off?
And.. when i get the turbo, should i get it checked out, or just get it bolted on?
finally, how much would labour be you think?
cheers,
Warren
https://www.sau.com.au/forums/topic/109753-rb25-turbo-onto-rb20det/
  • Replies 59
http://www.skylinesaustralia.com/forums/in...howtopic=109532
this is the turbo.. (pics there)
it says 45v2 does that sound like one with the nylon compressor to you?
can someone elaborate?
its a little more $ than a standard rb25 one, but if its got the nylon wheel then i would pay it..
PS i did search and nothing concrete about what to use..
thanks gordon for the link!
http://www.skylinesaustralia.com/forums/in...topic=90242&hl=
ok the above thread confirms it is an r33 series 2 turbo with the nylon compressor wheel :mad: , and i paid $410 for it
unfortunately i am not able to do this myself, even though i can hold a spanner...
what do you think as far as price for a workshop to do the install?
also add the costs of new trubo/manifold and turbo/exhaust gaskets..
i would upgrade to a split dump at the same time if you have the cash.. they make a fair bit of difference. (if you havent already)
new copper gaskets on the banjo bolts are a good idea too.
might not hurt to get someone to check the turbo too (couple of places so they dont try to talk you into a rebuild), just so you know your getting what you payed for..
gaskets cost about $30 I think.
install should cost about $250-$300
don't forget to use the actuator off the stock RB20 turbo on the new turbo.
gives you 10 psi whout boost conrtoller as the stock one does.
oh..
other than the Elbow off the turbo, you will also have to drill and tap a nipple on to the compressor cover or intercooler pipe for the wastegate hose.
to drill the comp cover, you will need to take it off the turbo.
I guess same goes for intercooler pipe.
Edited by GTST
Personally I have no idea - all I know is as the seller of the turbo, a) it is in very good condition, and was inspected by Bill at Adelaide Turbo Services, and b) I got reamed by SAU member Hooman who I bought this off from as a "R34 Neo turbo" and paid $650 for it.
Brendan :thumbsup:
Edited by Tangles
no no.... it's a good price.
just saying that on the RB25, there is a boost controller solenoid.
the hose goes from the intercooler pipe to the solenoide then through to the wastegate actuator.
on the rb20, the wastegate spring controlls the boost. it reaches about 10psi in stock form.
so there is no other controller so the vacuum hose goes from actuator to the compressor cover.
so to use this on the rb20, you need to drill and tap a nipple on to the compressor cover like in the rb20 turbo or drill and tap a nipple on the intercooler pipe like in the rb25.
I think you didn't sell him the ELBOW pipe (refers to the first part of the intercooler pipe) which is needed.
If you don't get that, you have to use the rb20 one and to do so, you have to drill out the 3 holes very close to the edges to make it match the larger rb25 opening.
when you use the rb20 actuator, on the rb25 turbo, you still run 10 psi through it.
and considering it is a larger turbo, it flows 25% more air at 10psi than the stock turbo at 10psi.
WARREN - use your boost controller anyway. it will help bring boost on quicker.
12 psi through the rb25 turbo is what I ran on my last car.
well it would drop to 11psi towards redline anyway. but I forgot to use the rb20 actuator so the bleed valve was making it boost fro the 7psi stock to 12psi..
I will be using 14psi through rb25 turbo for my current car.
when I buy it and install it that is.
GTST - as always, great advice.. thanks
so do you think its worth finding hte rb25 "elbow pipe" before i fit this, or just modifying the rb20 one?
keeping in mind that i will be taing this to a workshop and saying "do what you need to make it fit"
i'm thinkin of going to mercury motorsport so they know their skylines backwards and have probably done this uprade a few times...
that way if they need to get gaskets they can organise all that jazz, and whatever needs to be modified is done by them and added onto the price
CHECK THE WATERLINES!!!!
I can't believe there are all these responses and no one thought to ask whether it was an early or late r32.
Late rb20 has the same size banjos as the rb25, Early rb20 does not. You may need custom lines for it.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
