Hi Guys,
Just thought since this seems to be the most active cefiro/laurel forum i can find i would post some pics of my build up :D brought a 1989 cefiro manual rb20e ghetto spec...240kms on her....have since....sanded it back made her smooth and painted her :D (all in my garage) and installed the rb20det ;) etc done pretty well so far including the cost of the car i have only spent $2000.... but i have coilovers,intercooler, and 5 stud conversion to go..go some nice 17 inch tanabe 3 piece rims to go on her :)
https://www.sau.com.au/forums/topic/109871-my-taxi/
kinggts25 - Mate i would love to pick ur brains about the sanding back and respray! I am about to do the exact thing to mine and have never done it before....
Any chance of a write up of how to, what tools, products used & recommend!!! :D PLZ PLZ PLZ :D
Ie. what did u use to sand her back?? Primer... spraying techniques etc as it looks like a sweet job from that pic....
Ando
https://www.sau.com.au/forums/topic/109871-my-taxi/#findComment-2024503
how hard was the engine swap to do?
Took about an hour to get the old engine out etc...just used a beam in my garage and a block an tackle :) and about 25 minutes to get the new engine in....the most time consuming part was the wiring which was just pissing around etc...if you have an rb20DE ceffy it wouldnt be a prob though :P it's pretty easy....and the only other mechanical thing i have done on a car is change a diff :) this website is very good ;)http://www.geocities.com/lowrider_c33/
https://www.sau.com.au/forums/topic/109871-my-taxi/#findComment-2026359
Any chance of a write up of how to, what tools, products used & recommend!!! :) PLZ PLZ PLZ :P
Ando
;) yeah man if you have msn skylinegt25 (at) hotmail.com...pretty much i used real basic equipment i just spent ages on the prep which gets pretty depresseing... cleaned the car, sanded the body with 120 grit to chew thru the clear coat then sanded with 400 grit before applying the 1k etech primer...think i ended up with about 3 -4 coats of this after applying a lil body filler to smooth out some ripples and get rid of the aerial :) after that i left it for about 48 hours to fully dry etc again, then wet sanded it with 400 grit and then to 600/800 grit (the can only said 400 but i wanted smoother lol)...wash the car reaaaally well...make sure its dry...then just before painting use a wax/grease remover (prepsol or similar)...then ur ready to spray base coat...did 4 coats of this...leave for a good period of time and then wet sand this back with 1500 then 2000...then its time for the buffing....which is a mission...haha get a machine....
Basically follow the instructions on the can for times between coats etc...all the equipment i used was very cheap...
Compressor from bunnings $150
Gravity Feed Spray gun $60 (from trademe)
primer $70
Thinners $ 50
Paint (acrylic lacquer) $270
lots of drop coats for covering stuff u dont want overspray on!! $40
sandpaper etc like $30
and lots of masking tape lol get good stuff....proper painters stuff if you use the normal crap it wont pull of cleanly and takes an AGE to scrape the left overs off...
https://www.sau.com.au/forums/topic/109871-my-taxi/#findComment-2026366
Mate ur a legend!!! Thanks a million, appreciate the write up! Will be starting the first sand back hopefully this weekend....
1 quick question.... i assume u did the sanding by hand? Sand paper wrapped around something? Or just a good ole piece of sandpaper and i sh*t load of elbow grease?
Cheers again dude!
Ando
https://www.sau.com.au/forums/topic/109871-my-taxi/#findComment-2026378
WEAR A RESPIRATOR !!
Best thing I bought when I painted my kit. Did the primer on saturdy with one of those white paper masks and was soo f*kn high by the end I walked around dazed for about 10minutes :)
yeah forgot to mention that!! get a GOOD one! when buying the paint get a spec sheet it will tell you which filters to use! i work for a safety equip supplier so i got mine for about $14 they are the best investment ever!!! also good when sanding bog/fibreglass etc :P any thing like that....buy one or u will die.....my garage was soooo full of fumes and shit.... :huh:
https://www.sau.com.au/forums/topic/109871-my-taxi/#findComment-2026425
  • 2 months later...
one of the things i hated about being a panel basher :D all the bloody dust and fumes.
no wonder i cough so much now.
looks good mate... now i have a garage to work in im going to be doing something similar to my car... pity its a VL lol
https://www.sau.com.au/forums/topic/109871-my-taxi/#findComment-2240784
  • 1 month later...
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
