Hey,
on the way home last night, i was cruising along doing 85km, and all of a sudden the HICAS light came on, it didnt go out so i pulled over, turnoed of car and looked under at it,, (all looks good to me) fuse in engine bay is fine,
so i started the car, and all lights out, then about 4 or 5 seconds after the engine is started it comes on again...
Can anyone help me out here, or suggest whats wrong with it?
any help would be great,
Thanks
https://www.sau.com.au/forums/topic/109957-hicas/
I know the problem... The HICAS is still installed.
Get one of GTRGeoff's lock bars and get rid of it, the lock bar was the best $150 I've spent on my car.
agreed! that's your problem right there! :)
oh, and take the bulb out of the dash when u take off the rack, or it'll stay on and annoy the shit outta you
https://www.sau.com.au/forums/topic/109957-hicas/#findComment-2026717
hey Silver_R34_GT-T, is your car still under warranty since you only had it under a year?
HICAS is a real bitch as pretty much no mecanics know that shit in Australia. Ring up Nissan and have a chat, I think that Nissan at Windsor has worked on HICAS before, so I would say give them a go. If not try Fulcrum as they do steering.
Best of luck dude.
Chris
https://www.sau.com.au/forums/topic/109957-hicas/#findComment-2029047
thanks for the responses guys, I got in the car this moring, and bam it was on still, then half way to work, it went out and i havent seen it since..
Im hoping maybe it was a bad connection somewhere and it spat itself for a while.. **fingers crossed** maybe its a sign shes on her way out.
Bryn
https://www.sau.com.au/forums/topic/109957-hicas/#findComment-2029071
*Hops on bandwagon*
Dude, it's been said before but HICAS is NOT your friend. It also stands for "help I can't actually steer". Dumping it and getting one of GTRGeoff's lock bars in there was one of the best things I did to my 34.
Not a lot of point having a performance car if you don't have any confidence in its handling.
On the whole loose connection thing though, there are a couple of plug-in pin connector things on the motor and sensors attached to rack on the back of your car, maybe give them a wiggle and make sure it's all on tight and the connections are clean.
(pic added - the HICAS unit right before we ripped it off!)
Edited by jmac
https://www.sau.com.au/forums/topic/109957-hicas/#findComment-2034613
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
