well there is one next Sat at Oran Park.....but it looks like you aren't that local :)
If you want to be out with some Zed's ( boats ) some fast boats though , our next track day 17th September at Wakefield.
  • Replies 90
John,
Im getting closer and only using those "old slick" that you called crap!
I guess the real killer punch will be when the GTS track b!tch comes and eats you up!
Im coming to drop some stuff off today, see you then! Good times again, but yesterday was by far my best times ever.
John,
Good, bring it on, and do you think I will be standing still? We have plans.
Yes you now see slicks are not aways better and Michelan are much better than Yoko slicks and heat cycle much better. Yep when I was running these slicks everyone was saying " Yeah but you are runnin gslciks and not fair and bla bla" Now they are crap.
Bit of dirt on track on the right hander after the bridge I found out the drifters were there on the Friday night chucking it around.
I think the standout driver of the day from the SAU camp was Adam (abo) in the R34 GTT.
Automatic, semi slicks, R34GTT (not exactly the best suited model of skyline for circuit work) and less experience than both of you resulting in a 1:24.37 and only 1.7sec behind Pauls R34 GTR, thats tops!
No Doubt Abo does a fantastic job in that car, it has good suspension, good tyres and there is only about 5-10meters difference between us down the straight. Last time we were at wakefild Abo was faster then me by the same amount
Thanks for the pressure Duncan,,,it's all good though I'm up for it. Time to put the real diff in, a new clutch and a quick dyno job.
BUT there is another,,,,Mr Bullivant has done a 1.22.62. Yes Ian I am a snoop.
Neil.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
