NOISE TESTING
When - 18th March ( Tomorrow )
Time - 10am start
Where - Mt Cotton Driver Training Centre
Cost - !! FREE !!
Mt Cotton have come to the party :) as it's not something they normally do they have decided to give us 1 hour FREE so they can 'see how it goes' and decide if it's a service they should be providing (at a cost in future) - how many cars get tested will come down to how organised we are
Anybody planning on attending SkidPan/LVMA events in the future here is your oppurtunity to know where you stand in regards to the noise restrictions placed on cars participating.. 5 spots up for grabs
1. WiZardOZ
2. RhinoRebel
3. R33S2
4. jlnewton
5. SMR33
6. pear
7. lbfalcon
8. ed G
9. chaos
10.
Edited by WiZardOz
https://www.sau.com.au/forums/topic/109976-free-exhaust-db-testing/
will a fine turnup in the mail if we dont pass
No there will be NO come backs from this ... last SkidPan event there was a number of cars that "failed" but there was no problems .. just meant that those cars couldn't use the facility
Mt Cotton are only concerned with meeting the EPA obligations for the facility
Are they now restricting cars into the premise that they suspect are above Db limit?
If they find your car is over the limit will they note it, and restrict you next time you wish to use there facilities?
They are now enforcing a 90Db limit on cars participating in events at the complex. - Council / EPA requirements. Last time we had a members only SkidPAn event all cars got tested before being allowed on the SkidPan
As a side note I also noticed on the Dutton Rally site that all participating vehicles are required to meet a 90dB level (ie .. the legal limit)
Nah its just for competitors on the facility and they dont care how it got there or where its going its just for the competitor cars on their grounds and as an offer for SAU Qld to check before we actually do it and dont get knocked back after we've paid in advance.
seriously ed, easy fix, get a piece of 2mm steel sheet metal. Cut it into the shape of a 2 bolt exhaust flange, drill 20 or so holes in it (less depending on how quiet and how much power you want to loose) and then slide it up between your catback and cant converter flanges.
oh, who won overall?
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
