1994 Nissan Skyline
86xxxkms
12 months reg to who ever buys it
Car is immaculate and insude is like brand new
All orginal features, climate control, power steering etc
19 inch fusion rims with new rubber
lowred 1.5 inches with lovells
3 inch cat back sports exhaust
hybrid front mount intercooler
Pod with heat shield
Turbosmart Vee port BOX with adaptor
Carbon Fibre bonnet
Strut brace
Sports wheel
Panasonic MP3 Player ($600rrp)
3 gauges in single Din position, Volts, Boost, A/F
Will also throw in a 4 GIG IPOD
CAr is running stock boost. very clean will not find better
$16,000 ono
0407686611
Matt
Edited by XXE-R32
https://www.sau.com.au/forums/topic/110186-fs-white-s1-r33-gtst-vgc/
how negotiable is that price?
the 12 month rego would not be necessary as i would have to re register it in qld.
have you got service records to back up the km's?
I am neg on the price sothat is not an issue. I have full log books from japan with the car as i requested the car i import to have this.
If u need some more info please call me
0407686611
did u change the front headlights?? are they the series 2 ones thats clear?? or is it still the foggy series one?
Still have ur old bonnet? willing to seperate the cb bonnet?
Sorry selling the car as is.
the headlights are the s1 just i cleaned them to get them so clear
fark that is getting cheap, and it's so hot!
Any accident history?
Whats the service history like?
How modded was it when you got it?
And how long have you owned it?
Interested in Trades?
No accident history at all, it has full log books and serviuce history, it was stock when i got it and i have only had it since january i was the first owner, looking to upgrade to somehting bigger, commodore, falcon, etc
CAr is still availble
check your PM. thanks
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
