  • Replies 49
really should go - but 5 30am starts kill me, im like asleep by 7pm ;)
What kind of an excuse is that? I go every single wed nite (since the strip has been open) and I get up at 4:15am (used to get up at 3am).
I'll be there to spectate.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
