  • Replies 49
motor is standard
-35/40 turbo
-Plenium
-700 cc Injectors
-LOL GAS
-ummmm yeah
i am trying to get the thing to hook up off the mark
im doing
1.8 60 foot times
pretty shit if you ask me
i am aiming at 1.5 even 1.4
im working on a new suspension setup
and the car needs higher gearing 4.86 or so as im only crossing the line at about 6000 RPM (need to be 7800 RPM)
then after that im gonna try and pull some weight out of it
get it to 1200 KG then run again
hopefully it should crack 10.6`s
Edited by MR331307
Nice one Moanie.
Adrian = boring :D:P
I wanted to come but I didn't want to jinx you all and bring the rain. I think I'll go again next week. In my dream I went and it rained again so that's a sign I think - it will rain every time I go or say I'm going. :P
yeah, I woul have loved to have improved my times with a couple more runs. I thought I could have gotten another three runs in at the end of the night and made it 10 runs for the night :P
Well doneMoanie and Adrian. Best of luck in Qld on Saturday Mr Happy Happy Gas.
Well done also to Jason with the 11.3's :D
Yesss!!! well done jason :) and nice to meet you :(
hahah.. charlie... i reckon!!! the official said 2 more runs for sure! then that damn rain came down!! oh wells.. i got 7 runs all up so i'm happy :)
and i swear when you said you had a mitzu, that you were going to be in an old rickty 4 door thing! LOL!
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
