  • Replies 69
I think its going to come down to a personal choice for most people... I would say VL ... but I am biased owning 2 of them before moving up to a skyline....
again its personal preference, but I like the style of the VL a bit more then the DR30 which makes my choice easy...
https://www.sau.com.au/forums/topic/110521-vl-or-dr30/#findComment-2036162
I've got a DR30, as much as i love driving the thing, its a pain for getting parts, heaps expensive when you do find things, so unless you've got a budget behind you, and are not willing to trash shit outta them and crash them you'll be right...
If its your first car, prolly go the VL, just due to ease of parts...
So glad i've got my dr though and will never sell her :laugh:
https://www.sau.com.au/forums/topic/110521-vl-or-dr30/#findComment-2038372
or what wldcrd said, cause the first one gets trashed anyway. We all say we wont wreck it but im yet to see anyone not.
Little bro wanted to copy me and get a 33 for his first car but wisely listioned to me and got a laser. That laser was sold to the wreckers a few months back for $100!
https://www.sau.com.au/forums/topic/110521-vl-or-dr30/#findComment-2051615
not bad not bad. Are they are lighter/heavier car then say a 32 or 33?
Should get a vh and put a 'and justice for all sticker' on the back window. Play pantera really load drive really recklessly and yell out the window and death stare people at the lights. And have countless amounts of empty beer bottles on the floor and f**k it might as well drive pissed aswell! hahahhaahaha
https://www.sau.com.au/forums/topic/110521-vl-or-dr30/#findComment-2057753
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
