Hi, my names Nic i currently own a show Swift GTi and purchasing a R33 series 1 in the next month or so. Always loved the skylines, big fan of your forum too very useful. just a quick question im looking to purchase this body kit:
I have been told that it might be the GTR front bar (not original of course) along with the 400R sides and rear but i just wanted to double check before i start calling and emailing around. any info would be great, and if there is a forum sponser that does these kits that would be great too!
Many thanks, look forward to cruising with youse real soon.
:laugh:
https://www.sau.com.au/forums/topic/110616-hello-quick-question-about-the-r33/
cheers guys. the rims look good but i already have another design in mind. im assuming this bodykit then is the same? yeh i found that car on carsales, looks really good but the kms are a lil high :thanks:
Baby Blue Skyline 01
Baby Blue Skyline 02
im just a lil confused cause the sides look different and the frontbar doesn't have those nostrals on the front of the kit. sorry to be a pain, if theres a suzuki question ill answer it no problems, im just new to nissan.
Hey Nic.....front bar on the blue one would be a copy (?) of an early R33 GTR front bar....the N1 vents were only added on the series 2 (I think) and definitly the series 3 GTR.
Side skirts are diff....the 400r ones have the little vents in them on the rear 1/4 section.
Hope that helps
sorry to sound like a bit of a n00b but would the blue skyline kit be available cause im seeing alot of you guys have similar kits but with those nostrals and urs also seem alot lower to the ground than this blue kit? also is that skyline a Series 2 skyline and would that kit only fit a Series 2? any info would be tops!
Pretty sure that blue skyline is a series 1. The bonnet on a s2 has much sharper ridges, also the headlights on a s2 are slightly thinner & sharper than a s1.
Can't say that I'm a fan of that bodykit on the blue skyline though. 400r skirts look much more tidy.
    • If you like more modern stuff than the R series, you should check out a V37 400R, they are pretty mod friendly
    • Haha luckily we don't have emissions, inspections, or any laws against power adders here. They only thing they somewhat keep an eye out for are ridiculously loud exhausts.
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
    • If you are keen, have a look at my build thread. Car is for sale for the right money or straight swap for a F80 M3 LCI.
    • Welcome mate.  No point in over thinking it, buying any one of those cars you mentioned is not a smart or logical choice with the availability of many "better" (re price to performance) cars available to you.  The heart wants what the heart wants, buy whatever it leads you too.
