hey guys just recently bought an R32 GTST and am looking at gettin some exhaust bits like hiflow cat , catback and front/dump fitted, and not sure where to get it fitted or where to go.
if anyone has had stuff like this done before and can tell us where they went that would be really good or some exhaust places people know do a good job and arent dodgy.
thanx guys.
I had a system made by Everlast on a car (mind you it was about 10 years ago now, when they were still in Tolley Road). Daryl tried a couple of different muffler combinations on the car until he was happy with the sound.
I was really impressed with their service and prices were reasonable.
At that stage they were only doing press bent systems though, do they offer mandrel bent ones now?
yes they offer mandrel bent solutions now :P
yeah ive also been going there since tolley rd days ... its good to of seen them grow but i feel there pricing is good too
Exhaust Technology. One of the best known exhaust shops in Adelaide.
www.exhausttechnology.com
253 Goodwood Rd Kings Park. :(
Yeah got my exhaust fitted, and turbo and manifold gaskets changed there! Good price and work was done on time and had no probs since. Good work Exhaust Tech!
ok - buy the stuff you want fitted over the net (ie ebay, or www-based traders).
then call Ryan on 0401727440 and he'll fit it up for you
that process would save you hundred$ of dollar$
or call that lad Ryan and see what he could supply for your car (brand name items).
Best of luck with it - Brendan
Theres a guy called "Exhaust Wizard" in Willaston (near Gawler) does cheap systems, and quality is rather good. In and out in 2 hours..
yeah i reckon that's where jason got his done
they're pretty cheap to so that's a bonus :laugh:
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
