I may be buying a PC110 Skyline at an auction... I'm trying to get more info on it. I know it's G18 powered, but I'm confused by the rear suspension... From the pics I have, it looks like the car has leaf-springs. Is that normal for C110-chassis cars?
Also, does the L-series motor bolt right up in place of the G18 or are modifications required? Any other general info on the car? I can't find anything on the "P"C110.
The car in question:
The suspension:
The engine:
https://www.sau.com.au/forums/topic/110771-question-about-the-pc110-skyline/
Australian delivered C110's all had IRS - almost identical to the 510 / 610, except for the location of the spring and shock. All Australian delivered ones also had the L24 factory fitted.
i don't know how hard it is to convert this one to IRS and L power. (I assume the car - and you - are in Japan). If you're in Australia, then don't waste your time on Japanese auctions and just buy a local one.
Cheers
Hi Chokudori!
The first thing we must clarify is that this car is a short wheel base model C110. Sorry if you already know this... but basically there were the long wheel base (in sedan and hardtop) and the short wheel base (in sedan, hardtop and wagon). The long wheel base models were powered by the L20, L20E, L24 or S20. The short wheel base models were powered by the G16 or G18 (at least that's all I have seen).
The extra length of the LWB is in the engine bay. This is, of course, to fit the six cylinder engine. Otherwise they are pretty similar. The LWB got IRS whereas the SWB did not. I would imagine they could be swapped over with a bit of work but don't quote me on that!
A six cyl L-series engine will NOT bolt up. This is the main reason for the SWB and LWB models.
Do not kid yourself - this was the base model Skyline and never had any performance intentions. If you really want a SWB (some people do) then I think it looks pretty good (prepare to find a fair bit of rust though from what we can see on the boot), but I would just buy the bigger brother GC110.
Like Warps said though, if you live in Australia, just buy a 240K (they're almost exactly the same to JDM GC110).
edit: here is a picture that shows the shorter bonnet length a bit better, for those interested
Edited by Alfadog
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
