While your at it i need the middle vent replaced for my 1989 R32 GTS. Though some1 has told me its quite difficult to replace these things as they are delicate and difficult to remove without damaging or breaking them.
Any suggestions people?
If the one that is in your dash now is already broken, just rip it all out. Then the new one you put in will slide straight in easily.
Yes obviously :O the middle vent in my dash is broken and i dont care if it breaks more while trying to remove it but if i was to get a 2nd hand middle vent from another GTS how would i go about removing it without damaging it aswell??? :yucky:
or does someone know where we can purchase these vents from and perhaps an approximation of the price?
cheers in advance :(
Edited by LoNg_ShaNks
Anyone who is interested in a left vent (passanger's side) we can offer them for $103 + postage & handling of $8.50 (sent via registered post). Please state your interior code when making an order.
Forgot to add that these items are brand new genuine Nissan items.
Regards,
Andrew
BUY THEM NEW OFF NISSAN REASONABLY CHEAP TOO I RECKON
"Hi i'd like to buy a Nissan air vent please"
"Sure that's $3, oh wait what model Nissan?"
"Skyline Import"
"No problem thats $150+GST"
Its actually about $130 for the passenger side vent, and $178 for the double centre vent new from Nissan
The best way to put them in is to remove the whole dash.
Edited by Bl4cK32
  • 3 years later...
Justjap sell these genuine Nissan parts on their website. Both are in stock.
Centre vent - $125
http://justjap.com/store/product.php?produ...=268&page=3
Passenger vent - $105
just tried to remove the centre vent from a r32 gtr i/m wrecking, it had a small tiny crack, and, this became a bloody big crack and the whole thing just shat it self, when you look at them, the only way to remove is to pull whole dash out, gently squeeze the bottom and top plastic lugclips and gently ease it out, getting one in should be very easy.
I managed to get the LHS upper vent out in one bit, but it has sold.
Still got heaps of other stuff left, including a complete front cut R32 GTR
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
