jee tee - ah yes i waved back !! good effort mate, just drop yer 60fters and you'll be right :D
i dunno how im getting 1.9 60ftr's! but mine just loses top end speed/power. hmm...might need to change gears faster :)
r32 gtst pretty much stock 15.4 @93 mph that was my first time out. should go beta next time
Good stuff burnsie, great to see you out there giving it a go !!
:D
as people say "watch this space"as I know your times will drop (and mine again hopefully !)
Daniel Beers 33GTST, RNMENC : 11.75 @ 121
Adrian Hodgsons 33 GTST 2RISMO : 11.68 @ 117
Sau Nsw 400m Registry
GTR
DiRTgarage: 10.36 @134mph r32 gtr (two.06l stacey 11.95 @121 mph)
SCOOP: 10.9 @ 127.40mph r32 gtr
T04GTR: 11.7 @ 116mph r32 gtr
wrxhoon: 11.8 @ 117mph r34 gtr
JET-32R: 12.49 @ 106.66mph r32 gtr
Morgs: 12.53 @ 111 mph r32 gtr
GTRsean: 12.5 @ 116 MPH r32 gtr
GTR-27L: 12.7 @ 105mph r32 gtr
benm: 12.7 @ 112mph r32 gtr
GTS-t/ GTT
MR331307: 10.8 @ 128mph r33 gtst
DoughBoy: 12.0 @ 123.7mph White car r33 gtst
DoughBoy: 12.1 @ 119mph Black car r33 gtst[/b]
88silhouette: 12.119 @ 111mph r31 sil
OFENSV: 12.175 @ 118.14mph r33 gtst
legend01: 12.220 @ 111mph r32 gtst
qwikky: 12.3 @ 109mph r33 gtst
moanie: 12.504 @ 112mph r33 gtst
ECR033: 12.619 @ 116mph R33 gtst
mass iv: 12.91 @ 111mph r33 gtst
Guilt-Toy: 12.98 @ 108mph r33 gtst
yogi000: 13.1 @ 108mph r32 gts
spx25t: 13.354 @ 103.23MPH r31 25t
abobob: 13.405 @ 103.17mph r34 gtt :D
race_snooze: 13.4 @ 111mph r33 gtst
cerci: 13.522 @ 103mph r33 gtst
silver gts-t: 13.62 @ 103mph r32 gtst
RedDrifter: 13.7 @ 105 mph r32 gtst
JAS-25T: 13.8 @ 99mph r33 gtst
Shonen: 13.934 @ 97.4MPH r34 gtt
SECUR1TY: 14.003 @ ??? r33 gtst
JeeTeeEss25Tee: 14.01 @ 100.58mph r33 gtst
nath95: 14.04 @ 99mph r33gtst :yes:
GTShortie: 14.290 @ 104.24MPH r33 gtst
tomm0: 14.3 @ 98mph r33 gtst
raz0r$harP: 14.516 @ 95.98mph r33 gtst
evil_weevil: 14.5 @ 94mph r33 gtst :yes:
sindows: 14.8 @ 96mph r33 gtst
burnsie: 15.4 @ 93mph r32 gtst
Other
ido09s: 11.274 @ 121.79mph S14a 200SX
bmxwrx 12.59 @ 109mph MY00 WRX
wokburner: 13.02 @ 109mph 300ZX TT
PORTS: 13.433 @ 105.39mph z32 300zx
:yes: = improved on PB
Will be updated regularly. :P
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
