It has come time to sell the R33 which I bought 5 years ago from a local importer as I am building a new house and need $$ for it and have no room to store 3 cars at the new place. Bodykit came with the car and it was mechanically stock when purchased.
The car has spent the last few months sitting in the garage as I have another car as a daily driver.
General
1996 Series 2 M-Spec
White
90,000 KM On Clock
Twin Air Bags
Climate Control
Full electrics
2 Way Electric Sunroof
Prestige Alarm System
Engine / Performance Parts
Garrett GT30 Ball Bearing Turbo
(0.70 A/R Polished Compressor Housing, 0.82 A/R Exhaust Housing)
Braided Oil / Water Lines To / From Turbo
XTR Exhaust Housing Blanket
45mm Turbosmart External Wastegate With 1 Bar Spring
Custom Made Steam Pipe High Mount Turbo Manifold
K/N Pod Filter With 3-Inch Polished 304 S/S Intake Pipe
R33 GTR Stealth Bov’s
6 x Sard 550cc Side Feed Injectors
Bosch 044 600HP Intank Fuel Pump
Z32 80mm Air Flow Meter
9 Puck Single Plate Cushioned Ceramic Xtreme Clutch With 1800lbs Pressure Plate
4.8 kg Chrome Molly Super Light Weight Flywheel
HKS Adjustable Exhaust Cam Gear
HKS 600x300x76 Tube And Fine Intercooler
Custom Made 304 S/S 2.5 Inch Mandrel Bent Intercooler Piping
Cusco Oil / Air Separator
Custom Made 3 Inch Heat Insulated Mandrel Bent Dump Pipe And External Wastegate Adapter
Custom Made 3 Inch Mandrel Bent Exhaust From Dump Pipe Back
Highflow 3 Inch Cat and Polished 3 inch Rear Magnaflow Muffler With 4inch Tip
HKS Ionized Oil Cap
C’s Quick Shifter
Meridian Motorsport Oil Cooler
Suspension/Brakes
Blistein Shocks
Custom made king springs front and back (300lbs front, 250lbs rear)
Front strut bar
Rear Stabilizer Bar
Whiteline front/rear adjustable swaybars
Subframe alignment bushes
Whiteline castor/camber kits
Hicas Locking Bar
Wheel alignment to track specifications
DBA GTR 324mm slotted front rotors
Ferado DS2500 Pads front Comp 2 rear
Mechanical LSD Diff
Electronics
HKS EVC 3 Electronic Boost Controller
Apexi Power FC Programmable ECU
Apexi Power FC Hand Controller
Pivot Adjustable Shift Light
Blitz Turbo Timer
Apexi 60mm EL 2 Electric Boost Gauge
Apexi 60mm EL 2 Electric Oil Temp Gauge
Apexi EL 2 Gauge Controller
Trust Dual A Pillar Gauge Holder
Interior
Custom Painted Electric Blue Interior Highlights
Jetspeed EL White Faced Display Dash Kit
Trust Chrome Gear Knob
Alpine 3 Disk In Dash CD Player
Kenwood Front Splits
NISMO car mats
Custom Made Leather Electric Blue Handbrake & Gear Boots
Blue Recaro SR3 Front Seats
ERG 5-point harness
Exterior
Nismo 400R Front Bar With Grill Insert
Nismo 400R Side Skirts
Nismo 400R Read Bar
Stealth Rear Boot Lip
18-Inch White With Polished Lip Starcorp Racing Rims, 8.5 Inch Front, 9.5 Inch Back
235 x 40 Front, 265 x 35 Back Hankook K104 Tyres (80% Thread Left)
Clear Side Indicators
Tinted 30% Front And Sides, 20% Back Window
NISMO Carbon Fiber Pillar Garnish
Performance
1 Bar Boost – 260kw@wheels (Racepace Dyno)
1.4 Bar Boost – 312kw@wheels (04’ Autosalon Dyno Comp)
Car serviced every 5000km with full synthetic oil.
All Mechanical / Electrical work carried out by Ice Performance
Have receipts for most parts purchased for the car.
Car is setup for the track, throw some semi comps tyres on there and you will do some good times.
In Melbourne
Price - Looking for $31,500 ONO but open to resonable offers
Other pics can be emailed on request.
https://www.sau.com.au/forums/topic/111294-my-300rwkw-96-gtst/
  • Replies 41
if u drop to 20 i will buy ...coz its only a r33 gtst ! and a 1996 model ......!
even if u put over 10g under the bonnet u wont get a higher prices then 24g
Theres more than 20G I have spent on engine, suspension, interior, brakes etc etc.
Once you start modifying these things you will realise the cost, time, effort and headaches they can bring you.
When I get my next track car I will be looking forone that has already had alot of time and $$ spent on it coz I now realise what an effort is required.
  • 1 month later...
  • 1 month later...
  • 4 weeks later...
That's the best Series2 I've seen! Looks very professional too..not dodgy mods like some I've come across. I'm after a zed :) but I'd definately consider this if I had another few grand. Best of luck.
  • 4 weeks later...
If this car was registered in Adelaide it would be asleep in my garage at the moment!
I just don't think I would have a hope in hell of getting changeover of rego :(
That is a fark load of car for $23,500
Why would people not want to buy this if they where in the market for an R33?????? Maybe they're worried about getting defected?
Anyway, best of luck with the sale INASNT it seems like a very clean, well set up car :P
