Copied from MCCR website -
After the success of the 2003 & 2004 cruise and the support which this group achieved through the Melbourne modified car scean, The Melbourne Car Cruise Registry in conjunction with The Herald-Sun and The Royal Childrens Hospital are proud to present the 2006 Good Friday Appeal Cruise, on Good Friday, the 14th of April, in support of The Royal Childrens Hospital Appeal.
A lot of us and some parents have been associated in some way with the great work which the Royal Childrens Hospital in Melbourne has given the community. Now its our turn to give back to the hospital which has helped so many people in the Melbourne community, as well as people all around Australia and the world.
We have been talking to the Royal Childrens Hospital as well as Channel Seven and the Victorian police and will be running a cruise to raise money for the hospital, to enure that the benefits of this great hospital is available for many years to come.
The cruise will be running from Bunnings Warehouse in Vermont South and then be moving around to various points around Melbourne. Unfortunatly, due to health and saftey issues, we will be unable to use the "Telstra Dome" to park like last year. The Victoria Police have been notified about this cruise. All money raised from map sales will be put towards the appeal, as well as any money which you can add in the form of a donation.
It will be a fun cruise, the more people and cars we get to come, the more money we raise.
So get out there and spread the word about this cruise, it would be great to get as many cars as possible out there to show the community just what the modified car scean is about, but most of all, do it for the kids!
GIVE THAT THEY MAY GROW!!!!!!!!!
A very special thanks to Bunnings Warehouse for letting us use the Vermont South carpark to start this cruise.
Meet Point - Vermont South Bunnings Warehouse - Burwood Hwy Vermont South.
Date - Good Friday, 14th April 2004
Meet Time - 2.45pm
Meet Depart - 4pm
Bunnings Warehouse Vermont South
Proud supporters of RCH appeal 2006
Original link - Here
sounds like its going to be a good cruise, ill definetly try to get there as its for a good cause and to check out the melbourne car scene ...ill be coming over for the long weekend
I'II be going but in my black FTO with the FTO Aust club...my baby needs a work out cos I've been driving the R33 all the time. if I see some liners I will come have a chat
Guest
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
