Hi Guys,
I need to install my FMIC and will need to cut out the front intrusion bar (to fit my Hybrid Intercooler as per the specifications). The car will have to go through the pits after all the modifications and i want to make sure that i don't get pinned for having a modified (cut) front intrusion bar.
I don't think they will look.
Or should i wait till i get it over and then finish of the intercooler and piping. Until then i will have to re-install the old intercooler from my R33.
Advice would save me time and mucking around.
i have an r33 series 1.
https://www.sau.com.au/forums/topic/111437-is-it-legal/
yes its illegal. but in most cases they dont look.
i was driving around with no front bar, and most of my front bar support has been chopped away to fit my fmic and front bar. got pulled over and they didnt say anything about the amount of metal i took off, but how the exposed corners of it could cut someone that walks past my car.
i wouldnt risk it unless you had a front bar on. they cant ask you to take your front bar off to check can they?
https://www.sau.com.au/forums/topic/111437-is-it-legal/#findComment-2054877
  • 3 weeks later...
my mate got pulled up and he had cut about 10mm of o get the cooler in and they just put their hand up there and felt that it had been cut and they told him he had to reinforce it. i'm putting a new bar on where i have to cut half the front out so i'm making a bracket to go around the bottom so hopefully they will let me off
https://www.sau.com.au/forums/topic/111437-is-it-legal/#findComment-2096887
Doing any modifications to ur car is defectable because it is changing what the manufacturer inteded.
Meh that isnt going to stop anybody from modifying their cars.
stuff like that you just have to take a gamble, just do it neatly and they shouldnt pick up on it.
https://www.sau.com.au/forums/topic/111437-is-it-legal/#findComment-2098888
ive chopped my front intrusion bar for my fmic. i'll be welding some extra steel from the side bracket thingo to the front intrusion bar, then a flat bar across to give it some more tensile strength.
ill post pics once its all done :(
https://www.sau.com.au/forums/topic/111437-is-it-legal/#findComment-2099658
    • Nah, turn the boost up, break the gearbox, and enjoy leaving it parked for a few years while you save for a better box...
    • I see those two Stageas have the "punched 40mm hole" deregistered Japanese number plates 👍 Nice kouki group shot with the different colours too.
    • Ended up just being a loose exhaust bolt luckily.
    • Yeah I made that post way too early, sorry I must have assumed it was bad because it's a 20+ year old thrashed shitbox lol. It was just a loose exhaust bolt.
    • Like others have said, drop the power to give your drivetrain a % of reliability until you can up the drivetrain reliability  It isn't rocket science, build power to the weakest link with a % of safety Whilst upping the the reliability of the drive train is costly, there's no point in having the engine make big power if it keeps eating the drivetrain....ask me how I know, I had the tow truck on speed dial for a few years, and I spent huge amounts of money fixing issues and breakages that really would have been cheaper in the long run if I did it right the first time Me, I like a nice sized fudge factor, that keeps me off the tow truck
