Item: i have personalised plates for sale , never fitted to the car . they are gold background with black letter , slimline front and usa back .
number plates are 16ive : i give
Item Condition: as new
Reason for Selling: no longer wanted
Price and Payment Conditions: $395
Pictures:yes
Contact Details: 0403552715 or email me to [email protected]
Edited by iwon
https://www.sau.com.au/forums/topic/111467-personalised-plates-for-sale/
i been offered 360 and i still didn't take it as i want to buy new ones when i sell this one
thanks for your offer anyway . i'll keep them for 200 mate
i'll start the bid at 200 dollars.
yep they are perfect usa size to fit back bar of any import . and it looks better . very regretful sale but i have to sell them to buy new ones . thanks mate email me to [email protected] if your interested cheers
th reason im asking is because the plate on my 32 have been well bent to fit in number plate area, an i seen urs at it looks like it would fit in perfectly.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
