Finally got off my ass and went to a Street Meet. :yes:
R33 GTST, stock clutch, turbo and suspension, standard bolt on mods, 197kw @ 0.85 Bar
Front 235/45/17 Dunlop FM901s Rear 255/40/17 Potenza GIII @ 35psi, lowered to 33psi at the end
First couple of runs @ 0.7Bar
Run 1 - me:
60' 2.433
ET 14.971 @ 96.37 MPH
Run 2 - my bro
60' 2.733
ET 15.278 @ 97.22 MPH
Was misifiring (needs retune) so boost wound down to 0.65 bar
Run 3 - vijay
60' 2.221
ET 14.892 @ 95.55 MPH
Run 4 - my bro (vs GTShortie)
60' 2.343
ET 14.730 @ 91.19 MPH
Run 5 - vijay (vs GTShortie)
60' 2.107
ET 14.516 @ 95.78 MPH
- It was the first time ever at a drag, let alone competing- never seen the staging process or the 'christmas tree' until we were racing. Our first races we both staged 2nd and wasn't ready for the start. By the end of the night I was staging early and waiting to drop the hammer
- I can't do burnouts. Last one of the nite I tried to step onto the brakes but I think I did it too much
- Shifted too early, around 6500rpm
- Dropping stock clutch does NOTHING for launches. Tried it the 2nd time and tramped badly.
- Retune next month, so I can run on high boost
But it was the best rush! :) Definitely be back there soon...
Anyone got any advice from the results??
Vijay
https://www.sau.com.au/forums/topic/111764-drag-virgin-no-more/
1. At a street meet it doesn't matter if you launch immediately after the light turns green or wait a few seconds then go, your ET will be the same (reaction time doesn't matter), so stage up, compose yourself, then go when you're ready.
2. Don't worry too much about the burnout unless you're using soft semislicks.
3. Try lowering your tyre pressure even more, with 255/40/17 i'd be trying to get more sidewall flex by going as low as 20psi, but its a matter of trial and error.
4. What mods exactly do you have? I would have expected 95-97mph from a car making under 150rwkw.
What rpm are you launching at? With 255 rubber on the rear (drop it to about 20-25psi) you would be dropping the revs from around 4000-4500rpm i'd think? If you can nail a 2.0sec 60ft time you will drop close to a second instantly.
Rev it out more before changing, up around 6800-7000rpm somewhere. You may even be able to hold 3rd gear across the line and should be doing up around 100-102mph.
Hi, i've got virtually a stock car running a 3inch exhuast, stock clutch stock boost etc etc, my first time at the drags got me from a 14.6 down to a 14.1 at 97mph.
1st run = 14.53 at 96.4mph
2nd run = 14.32 at 97.15mph
3rd run = 14.11 at 97.7mph
4th run = 14.23 at97.5mph
5th and last was 14.64 at 96.4mph ( stock clutch gave up the ghost and slipped from the get go).
It was a great night and i will be going again now that i've got a new clutch and boost controoler. Can't wait to see what it will run now. PM me when you go and if i can i'll meet you there! Lots of sau ppl go.
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
