Cold Air Box
Ok, I'm sure its been posted a hundred times b4 but since I got no luck from the other forums i'll try again.
Does anyone have a template (or even some decent instructions) to build a cold air box around my pod filter.
I'm pretty mechanically challenged so if anyone has some good tips, that would be great.
Cheers,
https://www.sau.com.au/forums/topic/11220-cold-air-box/
mate its pretty easy to make one from the aluminium foil backed foam from clark rubber. $23 per m.
After you cut that stuff out to fit, you have a template for a metal one should you want it to look pretty, or you could just cover the foam one with fibreglass resin and paint it.
The foam is a fantastic heat shield.
https://www.sau.com.au/forums/topic/11220-cold-air-box/#findComment-188304
Lojikl,
If scissors & tinsnips aren't too challenging, read on..
Make a template around your pod from cardboard, ensuring that the corrugations are vertical. trim it so when u close the bonnet there is say 1/2 - 1 inch clearance. Then at intervals of about 1/2" around the top edge insert 2" brads ( small bullet head nails) where your template meets the bonnet. GENTLY close the bonnet - pushing the brads further into the cardboard. You now have a PERFECT profile ! carefully remove your template, carefully unfold it, trace it onto sheet alloy, play "connect the dots" - to get the top edge & hey presto - full sick, custom, and SEALED. BTW the best stuff for the top edge is neoprene pipe lagging - same stuff used on air-con lines. $2.50 a metre from Clark rubber !!
I've done 3 like this on different cars & it's simple - just takes time...
here's my Proton GTi..
note the neoprene has taken the shape of the bonnet... airtight !!
https://www.sau.com.au/forums/topic/11220-cold-air-box/#findComment-188396
Originally posted by JiMiH
And Jay: I don't suppose your template would fit an R32 would it?
Are R33s and R32s the same in that area? [/quoteJ
JiMiH - naaa, totally different. They look the same until you hold the template upto the R32 then you just scratch your head :)
J
https://www.sau.com.au/forums/topic/11220-cold-air-box/#findComment-189144
Guest KILLER-T
and one from the top so you can get a idea on the size of it and for cold air induction i just let it suck cold air through the holes were the factory I/C pipes went through. i tried some of that silver flexi duct but once i reached 1bar it would start to fold up and become restrictive
https://www.sau.com.au/forums/topic/11220-cold-air-box/#findComment-191247
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
