hi all
I noticed in my GTT that when I am driving around, the first application of the brakes dont feel as hard or firm as the second touch of the brakes.
Basically if I want to come to a stop at the lights, I will brake the first time, but if I let go of the brakes and step on it again straight away, this second time I step of the brakes it feels to have a better bite and is slightly firmer.
Why is this so? Is this normal? Seems like I need to bleed some air in the brake ssytem?
I recently had my brakes machined, new proper pads put in, and bled. I also have a brake cylinder stopper (which was not removed when bleeding the brakes, dont know if this matters)
The person who did it all bled the brakes from the front drivers side, to the front passenger, then did the rears. He said that order did not matter.
Its quite annoying as I thought my brake service would have made my brakes feel better than this.
Any help is appreciated!
you could try bleeding them again or take it to a brake place for a service / check, it almost soundns like the brake lines are flexing too much and taking up the slack
The thing is though, when I am actually stopped at the lights, no matter how many times i pump the pedal, it doesnt get harder.
So it only feels harder when i pump several times when i am coming to a stop.
Note: Formula Ferodo pads in front, Bendix Advance in the rear. (this might help)
call up any brake place, if they can't do it, they can point you in the right direction (and will usually do a free safety check & give their opinion of your problem)
Alot of people don't bother rebuilding master cylinders these days because it's often cheaper to just replace...
I was just about to say... With my clutch slave a new genuine nissan one was cheaper than a rebuild. With the brake master it was about $2 diff, just I had to wait for the nissan one so I went the rebuild.
get someone else to bleed it...
you are meant to begin bleeding calipers from the one which is furtherest away from the master cylinder.
so in the case of a skyline, rear left, rear right, front left, then front right.
well thats the unwritten rule anyway and i've never had a problem.
Reconditioning? sounds expensive! Whats the expected price to recondition the master cylinder?
I didnt think that bleeding them again would make a difference because at a stop, pumping the pedal doesnt really improve anything.
And pads were properly bedded in 3 weeks ago as per instructions on the box.
Edited by nuffsaid
I tend to find it in most of the cars I have had.. I actually like the feel, if you're just coming to a bit of a gradual stop you don't want it to lock up straight away.. second hard press if you really want to lock it up.
I always pump my brakes on stopping anyhow. It depends on the extent, but it may actually be fairly normal??
Yeah maybe its a common occurrence.
Its not that bad, I mean the brakes a better than how they were before I got all the work done to it.
I just wanted to know why its happening, its quite annoying but maybe not worth a master cylinder rebuild.
If i am driving on the road i dont feel this at all, but if i am in winding roads, i tend to find that when my brakes heat up a bit and are under some load if i am slowing down, then let off quickly then back on right away, it slows down faster.
I've put it down to the fact that i dont have slotted rotors and the gasses build up and releasing for that 0.1s gets rid of it all?
Seems a bit cheap, is that inclusive of labour?
rebuild's aren't that hard, all they do is disassemble the master cylinder, clean everything in metho, check the bore and then replace all of the o-rings and seals etc.
(if bore is pitted or worn, have to replace master cylinder...)
up to you, but it can't hurt going and getting a quote...
As advised via PM, sounds like pad knock off to me. Get the run out on the rotors checked. They were machined on the car, which can be risky if not done carefully.
;) cheers :O
Master cylinder recondition inclusive of genuine parts and labour $400
The car feels like there is some slack in the brakes. The first centimetre or 2 offers no bite. Is this adjustable?
Have reconditioned the skyline1 1/16 brake master cylinders before for about $250 (give or take) master only already off the car.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
