Hi guys, As title says i need a wheel alignment bad. Front left outer part of the tyre has gone down to almost nothing in 400km of driving. I knew it needed one but didnt know that bad.
I went to maddington tyre and suspension and they dont have the specs for the Cefiro. Wouldnt even look at it.
Another tyre place tyre place down the road didnt have the specs for them either.
So where do you guys, obviously aiming at people in WA get your cefiro done?
Either that or if someone could tell me the specs to get wheels aligned so the individual workshop can do it.
I have a 88 Cefiro I believe its non Hicas too not sure if that makes a difference.
Let me know
Thanks in advance
https://www.sau.com.au/forums/topic/112326-wheel-alignment/
no ou're not wrong konect it is what it is
meanman dont listen to them
take it to ian diffan the tyre factory
warren's tyre &brake centre is my regular
then there' wilkinson suspension centre
they're all over morley and embleton way. just north of the river,.
it shouldn't cost more than $50.
Edited by Mr Eps
https://www.sau.com.au/forums/topic/112326-wheel-alignment/#findComment-2072107
Yeah, weird. I thought it was a bit of a standard thing (allign to straight) But both places said the same thing. They need to know the toe and camber and i think he said something else, not sure.
Ive heard good reports about Wilkinsons so might give them a ring.
https://www.sau.com.au/forums/topic/112326-wheel-alignment/#findComment-2074488
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
