Thai ORchid...Thai Orchid...Thai Orchid
For $25 and the best Thai you can eat how can you go wrong ?
We ALWAYS have a good feed, good chat, good grog, good parking, good service, good....well just bloody good.
It is also close for everyone except public transport people, but we are a C A R club
  • Replies 101
Posted Images
*joins in chant......Thai Orchid Thai Orchid Thai Orchid :D
If we step it up, we should go to Hurricanes at Bondi - i used to eat at Prime and Kingsleys every fortnight, tried hurricanes and never went back
Its also cheaper so more people would be able to come.....and has a FULLY stocked bar :O
Hate to disagree, and as much as I love Hurricanes, their meat isn't on the same level as Prime. More heavily marinated and "tasty": yes, but quality of meat: no.
But I like Hurricanes, and wouldn't be against going there if that's where we end up :(
But I like Hurricanes, and wouldn't be against going there if that's where we end up :mage:
Yeah you are right - the quality isnt the same as Prime, but, id say still far better than most places
That Hurricanes sauce is addictive - you can smell it from the end of their street!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
