Hey Guys
I got a top mounted GT3540 which has a 4" inlet with a 4" bend then a 4 to 3.5" silicon reducer plugged into the AFM then the filter so there is a short run to air filter.. Good setup ?? Well it looks good but it drives like SHIT.
When comming off boost to idle it will stall. The car would cough and backfire and jerk all the time and it HUNTS like crazy!! so I heard somewhere that the AFM shouldnt be close to the turbo so i tried a way to move it away.
So what i did was went to the hardware store and purchased some 3.5" PVC piping and a 90deg bend. We hooked it up and had the air flow meter sitting right in the gaurd where air flow runs through.
The results were suprising. it went totally awesome. The car sounded OFF ITS HEAD when comming onto boost and letting off the accelerator (air noise was just awesome) ALL the idle issues were resolved and all the popping and coughing and jerking just completly went away...
So i then decided that PCV plumbing pipe is dodgy and i really did not want my AFM to come off and run over it lol so I purchased some 4" flexible hose and put it on so its now 4" from the turbo straight to the AFM.
I found this setup to not work as well as the PVC 3.5" pipes. It does not sound no where near as good and it coughs a little and it nearly stalls when you come off boost. (still its MUCH better then the AFM close to the turbo but not as good as the PVC setup)
Wouldnt the 4" pipe be better ?? the AFM is 90MM and the pipe is 100mm so does anyone know why the bigger better pipe does not work as well as the $20 PVC plumbing job we did. Normally dodgy is never better but in this case... I am confused.
Is it because the PVC is the same size as the AFM and it runs more stable that way ? if thats the case should you use pipe the same size as the AFM all the way through for best driveablilty.
So yeah anyone know whats the best way to sort this one out. I am thinking of getting a 3.5" pipe made up from the 4" bend to see how it goes but that will cost around $150 so anyone been through this before ?
Edited by Guilt-Toy
well ive got a shitty pod adaptor on that is for a 80mm r32 afm to a 80mm pod.
Atm its running a 80mm pod to the 90mm q45 afm, then the std r32 rubber inlet hosing to the turbo. I havent had any idle issues with this setup, but it does play with the voltages a little when tuning.
Im going to *insert lazy comment by Cubes here* fit a 5" inlet pod to the 90mm q45 afm when i can be arsed making the adaptor to take out my restriction. When i replace the highflow im running now (on the 3lt) to a gt30/35r? ( havent decided) i'll change the piping to suit.
Always ideal having good flow infront of the turbo i think.
i have similar sort of issues when backing off, but i just think its the non recirc BOV thats causing it.
i have 100mm inlet .. then a 45 bend in 100mm stainles, then to a 80mm reducer to the Z32 afm ..
no room for the recric to really go, i'll try to post some pics, but i dont know how the length of the pipe would affect the idle.
I have the same setup but mine goes to a Q45 afm
Edited by RB power
i dont think it should make a difference as you say.
Mine was pretty close to my GT30 and i never had a problem with anything.
But then, i had a re-circ BOV :)
You have room im sure :)
I would have thought plumbing stepping up between the 90mm Q45AFM and the turbo inlet would offer no advantage . Since the comp covers are aluminium it would be very easy to have the inlet boss turned down to 90mm , its only 5mm off the radius of the boss and the plumbing can be one size - no expensive silicon reducers required .
Cheers A .
But then, i had a re-circ BOV :(
You have room im sure :D
BOV is where the washer bottle used to be with the plazmaman plenum ..
more of a "i cant be arsed making a pipe from one side of the engine bay to the other for the BOV" lol
stop pointing out my lazyness lol
what do we know about the chuffing/shuffling problem on the compressor side so far? what causes it? i think a workaround is to move the airflow meter after the compressor outlet, pre TB.
does it only occur after u come off boost?
does it happen at idle by itself or in low rpm range?
No it can even occur after driving in vacume and you slow down to a set of lights.. when you stop the engine will hunt and dump in heaps of fuel (lots of black smoke) and run rich as. With the AFM moved away from the turbo (under the front gaurd) it works perfect with the dodgy pvc setup and works acceptable with the 4" flex hose.
What would be the benifits of moving the AFM onto the boost pipe. would the AFM handle it ??? I am starting to think i should replace the flex hose with a 3.5" mandrell bend + pipe and see how it goes.
i dont think theres any issues relocating the airflow meter
i wonder if it could be tuned out. any chance you see what map tracer shows?
Yeah map tracer goes off its head... it does a nice circle.. in around the first 5 x 5 box's etc....
It hunts and runs like crap. Move the AFM away from the turbo and its great.
apparently HKS make a little unit called IDS or something that catches the idle and stops this issue but they are worth about $400.
Moving the AFM away from the turbo works great. Just cant work out why the 3.5" pvc pipe works better then the 4" 100mm flex hose!!!
Definitely sounds like air reversion through the AFM. If it is you can see it on the AFM voltage trace you get spikes and troughs as the air bounces between the compressor and the AFM. I found a couple of things help;
1. Run as large a diameter pipework as you can. I use 100 mm alloy, mandrel bent pipe with a 100/90 silicone reducer to fit the Q45 AFM
2. Make the distance between the AFM and the compressor as long as you can.
3. Make the bend angle as large as you can. I noticed in the pictures some of the bend angles in the inlet pipework are around 30 degrees and they start almost straight off the compressor. Mine has a straight length off the compressor, about 300-400 mm long. Then a larger angle bend, maybe 60-70 degrees. A very short, straight length into the 100/90 silicom reducer.
4. Running a heat shield, I found the hot air coming in from the rear of the radiator made the rough idle worse. Particularly when the fan was running. The heat shield on its own made a difference.
Some logic.........the longer/larger diameter is obvious, it simply gives more air buffering space between the compressor and the AFM. The larger angle bend is to stop the air off the compressor hitting the AFM directly, it has to bounce off the walls of the pipework.
That worked OK at around 600 bhp using the T66, I wonder how it is going to go with another 200 bhp and a bigger turbo. :D
:( cheers :(
without knowing any more about the eids i suspect it just watches for a big drop in AFM voltage and when it see's that clamps it for about 5-6 seconds to try and stabalise it. it could also be done on the AFM voltage ramp in the FC with a fair bit of screwing around
im sure cubes could fix it :D
That worked OK at around 600 bhp using the T66, I wonder how it is going to go with another 200 bhp and a bigger turbo. ;)
:O cheers :D
Thanks Mr I work in my own workshop and I know everthing LOL :)
I knew i was on the right track there.. But can you shed some light on why the 3.5" plastic PVC piping works 100 times better then the bigger 4" flex hose the same length oh and the PVC piping sounds heaps better too...
WHY!! *scratches head confused as hell*
LMAO....
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
